Results 1 to 10 of 14
Thread: Front Shocks
    Regular Member PORKBALLS29's Avatar
    Epping
    Default Front Shocks
    Hi all,
    Possibly looking at changing my passenger front shock to see if it cures my Knocking problem that has reared its ugly head again, I was wondering - should I be replace both fronts at the same time? (only one is knocking) are all the shocks the same across the Vec/Signum range? I did think about fitting some Bilstien B4's and eibach springs but finance is not permitting at the moment. Any advice would be great.
    Howard
    WGAF#5
    they are listed as the same from the 1.8 to the 3.0 v6 diesel and 2.8T
    on the Bilstein product page for B4's
    http://web1.carparts-cat.com/default...&30=84&31=4956
    Regular Member Jezzy's Avatar
    S.E
    B4's will be cheaper than Vx shocks.
    Regular Member gibbon7000's Avatar
    lincs
    If i was you I would change both.
    Epping
    Ideally i'd want to change to B4's but with spring i'm looking at about £300+ without fitting so I was just thinking about do the fronts at the mo. Finances are tight up to christmas.
    Sep 2010
    my SRI 04 plate went at three years old. My local mechanic fitted a VX shock. Supply and Fit was on £120.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Quote Originally Posted by PORKBALLS29 View Post
    If one's gone the other has to be on notice - why change the springs though before they need doing?
    It's my intention to fit eibach and B4's, but I can't afford to do it unless the old ones need changing, so that's my plan.
    Sep 2009
    essex
    Have you changed the drop links? was causing a lot of knocking on mine
    Epping
    changed drop link on that side and still knocking. Car has been into garage i trust and they said the only thing they can find is slight play in the shock. Really i only want to replace the one shock that is knocking. The other side there is no noise at all, i'm just asking if i have to change both at the same time and if all the shocks are the same for the siggys. If i do have to replace both fronts would it work if i had b4's on front and standard on back?
    Mar 2007
    Finland
    Remember to change the strut top bearings too.
  1. front shocks
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2012, 20:36
  2. front shocks
    By chris1804 in forum Suspension, Wheels & Brakes
    Last Post: 8th May 2012, 06:53
  3. front shocks
    By mattbrad30 in forum Suspension, Wheels & Brakes
    Last Post: 10th September 2011, 14:23
  4. Need front SRi shocks ... where from though?
    By kev.whitehead in forum Suspension, Wheels & Brakes
    Last Post: 28th July 2011, 21:05
  5. Front shocks/ b4s
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2011, 23:40
