Hi all,
My 54 plate Vetra failed its MOT at the weekend, the main fault was N/S ARB ball joint has exessive play.
Is this the drop links? I presume it will be worth doing both sides.
Hi all,
For the cost you might as well replace both sides as they are cheap and easy to fit, see how to section which has a step by step photo sequence.
Thanks for the reply.
Are the anti roll bar ball joints more commonly known as drop links. I would hate to change the wrong parts.
Yea, they're known as drop links.
