Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Help fitting the CD70
    Regular Member TopRod's Avatar
    Liverpool, UK
    Talking Help fitting the CD70
    I've just bought a CD70 MP3 from eBay. It's from a 2008 SRi and it's coming with;-
    head unit
    screen
    sat nav cd
    sat nav aerial and wiring from roof to head unit
    the rgb cable from head unit to screen
    the the lower compartment under heating controls with aux-in.
    It's in perfect condition, no scratches and I got it all for £450. It hasn't been delivered yet. I'm gonna fit it myself the only thing I'm not sure about is how to take off the grey strip on the dash under the screen so I can replace with the CID.
    Thanks guys.
    Devon
    101 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Open glovebox mate and put fingers under trim and pull as soon as its off you will see the torx screws holding vents in,undo these then remove vents and unplug the screen plug.
    HTH
    Irmscher Insignia CDTI 130
    South West
    Ahhh, so it was you who bought it!
    I was tempted to get it due to the fitted Aux In. Dead easy to fix mate, even a dumb ass like me managed it!
    Just to add, are you going to be using the GPS antenna loom or getting a standalone Fakra GPS connected one and put it under the centre speaker compartment?
    If you are using a loose one, then a top tip is use a coat hanger, or bit of wire to get the plug through into the firewall area. It takes a bit of jiggling about, but it will come through eventually.
    Rgds
    Aidi
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    Aidi -> theres one more complete on ebay for 399.. with just the same
    South West
    Thanks mate, I have since been in contact with yysnet and will probably go with his add on service to get the Aux installed.
    Aidi
    Liverpool, UK
    HAHA! I knew someone would get onto that, yeah it was me, I saw it and just had to have it. I'm torn between using the arial that it's coming with or the fakra one. If I decided to get an aftermarket GPS arial which is the best?
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    any 10£ one with correct fakra plug will do
    Liverpool, UK
    I'll have to look at the the connection when I get the head unit. Anyone gis a head up on which is right connection and which gives the best connection.
    If I buy an aftermarket one I don't wanna go to use my sat nav and it say 'no signal' or 'cannot find satellites'. It has to be a strong sinal receiver.
    Nice one.
    Berkshire
    29 Post(s)
    Vehicle : Toyota
    Trim : Yaris Hybrid
    Engine : 1.5 Hybrid
    Year : 2021
    Mileage : 5525
    if its any help my aftermarket one only really works when I stick it on my roof (starsky and Hutch style)..I havent tried putting it in the front speaker compartment yet tho,but am sure when we tried it just resting on the front dash it still didn't pick up well.
    Liverpool, UK
    Quote Originally Posted by soulman View Post
    How have you been using your then mate?
  1. rca converter for fitting sub to cd70 nav
    By lochgilp in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2013, 21:54
  2. Fitting a sub to cd70
    By Keith Fusco in forum Electrical & ICE (including SatNav)
    Last Post: 25th August 2012, 15:03
  3. help required fitting cd70 sat nav
    By deano1 in forum Electrical & ICE (including SatNav)
    Last Post: 20th September 2011, 19:58
  4. CD70 fitting
    By leonvectrac in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2011, 23:54
  5. CD70 fitting help!!!!!!!!
    By m3ath3ad in forum Electrical & ICE (including SatNav)
    Last Post: 11th March 2009, 21:22
cd 70 10 satellites no signal
