Results 1 to 10 of 14
Thread: Exhaust emission light and loss of power below 2000 revs
    Bexley
    Default Exhaust emission light and loss of power below 2000 revs
    Hi,
    The Exhaust emission light has come on and i have a loss of power below 2000 (ish) revvs.
    It pulls fine after that but on pull away does not want to go.
    I have a CDTI 150 50k miles on a 07 plate.
    Any ideas what it could be ?
    Had a look at some of the pipes and can't see splits.
    It is an auto so not sure i can get the codes from doing the pedals trick ?
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Could be the boost sensor or the EGR need a clean just about to do mine today
    also check the vacuum pipes for splits
    Steve
    http://www.saabscene.com/forum/index...topic=31642220
    This is for a 120 but should be the same for a 150 apart from the EGR is not in the same place
    Bexley
    Cleaned the EGR and it now works fine...
    The warning light has gone off after a short drive.
    Hopefully that is it now..
    Bexley
    One thing i was going to ask is...
    I cleaned the EGR but could not disconnect the plug.
    i pulled the yellow lock bit down a couple of cm but could not get the conector apart.
    Should i have pulled the clip down further ? Did not want to break it so just cleaned with it still attached...
    Bexley
    Well
    the emissions light has appeared again..
    i cleand both EGR and boost valve this time but light remains.
    can i continue to drive and ignore the light ?
    the car seems to be running fine.
    was thinking of blocking off the EGR but i think the light will remain.
    Any ideas or suggestions please ?
    Regular Member paul-west-76's Avatar
    Feb 2011
    wolverhampton
    Vehicle : Insignia tourer 1.6 elite
    Trim : elite
    Engine : 1.6 cdti
    Year : 2015
    Mileage : 104000
    have a look at the 3rd injector, i had the same thing, did all the usual. egr replacement, boost sensor and reconected the linkage on the swirl valves but after a week the problems returned, did the 3rd injector change following the how 2 on the site and been great since, other than that the symptoms are similar for inlet manifold issues.
    Mar 2011
    essex
    Try looking at the carbon canistor mate, i think its wat its caused anyway. my ex misses has a brand new zafira 1.9cdti and after 200 miles it lit up, its normally caused by poodling around, i cleared it by taking it for a good thrashing down the motorway, cleared it right out and sorted the problem.
    Dec 2010
    London
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    Administrator plasma's Avatar
    On the Forum
    535 Post(s)
    Engine : 150
    Mileage : 74000
    Had this happen to mine, it can come on when a regen is interrupted too many times... Caught it doing it once and took it for a blast and the regen completed (could tell because consumption went up to 0.9Gallons per hour) and not seen it since
    Bexley
    Quote Originally Posted by paul-west-76 View Post
    Thanks for the reply.
    When i look at the 3rd injector how do i know if there is an issue (what am i looking for ?)
  1. Loss of power - high revs
    By ac14 in forum Engine & Drivetrain
    Last Post: 19th March 2012, 22:11
  2. Spanner light and loss of power at low revs
    By Marky in forum Engine & Drivetrain
    Last Post: 29th April 2010, 16:34
  3. loss of power, revs bouncing
    By eaglepva in forum Engine & Drivetrain
    Last Post: 28th February 2010, 22:10
  4. Can you Help ~ Loss of Power, High Revs
    By Diet1985 in forum Engine & Drivetrain
    Last Post: 28th June 2009, 18:23
  5. 1.9 cdti power loss at low revs
    By topdogs in forum Engine & Drivetrain
    Last Post: 27th January 2008, 03:56
