Results 1 to 7 of 7
Thread: ~~ NO CLUTCH!! Help!
    Nov 2010
    Melbourne Australia
    Default ~~ NO CLUTCH!! Help!
    Hey Guys,
    My Names Lewis
    I just recently bought a 2000 Holden vectra olympic Edition..
    im just learning how to use manual for the first time..
    ive driven the car once since i bought it and now the clutch has gone..
    What is happening , when i put my foot on the peddel there is no pressure it just pushes straight to the floor, as if it feels like there is no Clutch fluid..
    Ive checked the Clutch fluid Resivoir and there is fluid in there, so i topped it just a few mls up..
    Any ideas what could be wrong, is there a leak in my gearbox or do i need to bleed it..
    any kind of help would be very much appreciated!!..
    Thanks for your time
    Regards
    LewisT.
    Admin & Membership Manager bigmac's Avatar
    Jul 2008
    Devon
    101 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Sounds like slave cylinder but i would wait for other answers
    Irmscher Insignia CDTI 130
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    it meant to go to the floor! does it come back up on its own?
    Regular Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    Quote Originally Posted by markj23 View Post
    I think he means it goes straight to floor with no resistance on the pedal !!!!
    I have had the actual activator lever from slave to thrust race snap on our Land Rover pain in bum to change. In older days the slave cylinders seals were the most common fault on clutches. Someone with TIS should be able to send you a exploded diagram of the clutch assembly
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    have you tried bleeding the clutch? try the simple options before thinking its broken
    Regular Member Vectra_C_Chris's Avatar
    May 2009
    Perth Western Australia
    Lewit. I recommend asking OpelAus.com.
    Your driving a Vectra B. And this is a Vectra C forum
    See you on the flipside.
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    2 Thread(s)
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Engine : Z19DTH
    Mileage : 166000
    i know its probably a bit late but for future reference ive just got my vectra and when i brought it i took it for a test drive and the clutch was fine but went to drive it the 100 odd mile journey home about 30 mins later and the clutch pedal went straight to the floor, turns out the flywheel had stuck in therefore meaning the release bearing had to reach further and this meant it over stretched past its seals blowing the seals leaving me with no clutch pedal operation atall meaning a new clutch kit and dual mass flywheel, load of fun lol
  1. clutch pedal really soft after new clutch
    By valvelift in forum Engine & Drivetrain
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. 3.2 GSI Clutch
    By cmowen in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 13:31
  4. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
