Results 1 to 10 of 18
Thread: Cruise control indicator
    Regular Member 111's Avatar
    Stockton-on-Tees
    Default Cruise control indicator
    Do all Signums have a light on the dash that shows when the cruise is on?
    mine works normally but I dont have the little dial indicator showing? if its just the bulb are they easy to change? it doesn't bother me to much I would just like it right.
    Its a 2007 2.0t
    Jul 2009
    Brighton
    My cruise control works fine and put the light on the dash too.
    it's a 1.9 CDTi (150) Design.
    Does the light come on when you first switch the ignition on (can't remember if it does a lamps test then). Maybe it's just the bulb/LED gone!
    Regular Member ROCKATANSKY's Avatar
    Apr 2008
    suffolk
    I'd say bulb gone mate
    13 Post(s)
    Quote Originally Posted by ROCKATANSKY View Post
    I thought all the "bulbs" in the speedo housing were actually LEDs.
    Aug 2010
    Antrim
    While LEDs are generally very long lasting compared with a bulb, they still can fail. Happened in my first Mondeo, and had one that would not work when the car was very cold in the second Mondeo.
    Stockton-on-Tees
    Thanks for the replys guys, it never comes on not even when I just switch the engine on, is the dash easy to remove?
    Aug 2010
    Antrim
    TBH, unless there is several LEDs needing replaced, or some other job needing the dash taken out, I would leave well alone, as quite often a refitted dash is never quite the same again, in terms of creaking etc.
    Regular Member Exclusive BV's Avatar
    West Midlands
    No it does not illuminate on start up as a test unfortunately.
    It would be good if there was some sort of lamp test mode when everything could be turned on at once to see if any bulb has blown
    VXR where are you now
    16 Post(s)
    Vehicle : Nissan GT-R R35 Vectra XP2 CDTI
    Trim : Nissan GT-R R35
    Engine : 3.8 twin turbo 700hp
    Year : 2010
    there is a function on op com/ vaux com for that
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
  1. indicator/cruise control stalk
    By dave1419 in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2012, 15:44
  2. indicator stalk for cruise control
    By solorider in forum Parts for sale
    Last Post: 4th November 2008, 12:25
  3. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  4. Indicator & cruise/computer stalks
    By Ozz in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2006, 08:15
https:www.vectra-c.comforumshowthread.php122596-Cruise-control-indicatorpage2
control indicator in opel vectra c
