Hi all,
I am no expert on auto boxes but have a second vectra elite 150 auto first was a 54 plate, current car is a 58 plate, this problem has been experienced with both - if it's a fault I would like to try and get VX to fix while it is still under warranty - but you know the problem they will want to charge me to look for it and then find nothing.
The problem is intermittent and happens when the vehicle comes to rest with foot on the brake, sometimes you can feel the car pulling as if it wanst to drive on, at the same time the economy on the screen shows 1 gal / hour instead of the usual 0.3 to 0.4 gal / hour. I can move the gear shift into neutral or even Park and the "pullng continues". If i turn the engine off and back on the problem goes away, if I turn the engine off in Drive it goes off with quite a considerable jump.
I cannot believe that the above is normal and am concerned that it will get worse and end up costing a considerable sum.
Has anyone experienced anything similar, or does anyone know the cause and remedy - any help would be appreciated.
This car has now done 55K with me doing the last 25k in 5 months or so - problem has only just arisen, car has just been serviced - happened before and after service, apart from this gear box is smooth and responsive - most of my driving is motorway at cruising speeds (yes even in the UK) with engine around 1500 to 2000 rpm.
Look forward to your replies.
Paul![]()
If the tickover is high they can creep in drive with NO brake or Park selected, but what you're getting needs sorting - soon.
