Results 1 to 10 of 11
Thread: Strange warnings
    New Member _HG_'s Avatar
    Oct 2010
    Southern Sweden
    Default Strange warnings
    Opel Vectra 2.0T 2005
    Suddenly, short time after start (could be anything from a few seconds to several minutes) this warning light shows up. Apparently there is no problem with the anti spin function.
    Some times, also the power steering warning shows up. But there is no problem with the power steering. It works perfectly well.
    Anyone out there that knows what's wrong ?
    / Hans
    Regular Member Marcosuk's Avatar
    Fife
    Have you checked the power-steering fluid level??
    Does the traction control light go out when u first start car up??
    Oct 2010
    Southern Sweden
    The power steering fluid level is OK.
    When I start the engine everyting is OK, but the traction control warning is lit up after anything from a few seconds to several minutes. It has become worse over time. A couple of months ago it could happen only rarely but now it happens every time I use the car. The power steering warning is lit up rarely, though.
    The traction control warning then stays lit up until I stop the engine but the power steering warning can go off again after a few seconds.
    I suspect some kind of faulty sensor, but I am just guessing.
    / Hans
    Engine : 1.9 CDTi
    Maybe someone local (No Location in your profile) could read the fault codes to save you guessing.
    Only time I ever had those two lights was when they lit up at the same time, on full lock reversing into a space. Turned out to be the steering angle sensor. Never did anything with it though.
    Oct 2010
    Southern Sweden
    The problem is solved.
    It was a sensor at the steering wheel shaft that gives the steering angle information.
    It caused both warnings.
    The sensor is replaced and the system is OK now.
    / Hans
    Mileage : 000
    Big Sig was correct then, Good mind of information.
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Trim : SRI VX-LINE NAV
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 25000
    Quote Originally Posted by ed taylor View Post
    Yes his advice is always invaluable.
    Wales, UK
    Problem solved, ill remember this one
    Jun 2009
    Middlesbrough
    Hello
    I am getting the same warning lights coming on my dash, have phoned the stealers and motor factors asking if they have a steering angle sensor and they have no idea what i am talking about, does this sensor have a specific name or part number?
  1. Dash warnings!?! taking the p*ss?
    By TAB in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2013, 23:11
  2. Disabling screen warnings??
    By SlowCoach in forum Electrical & ICE (including SatNav)
    Last Post: 19th December 2012, 22:27
  3. Various Warnings + Electric Failure
    By vaughaag in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd December 2011, 17:44
  4. would these set off warnings ?
    By bertbuckie1 in forum General Chat
    Last Post: 13th May 2009, 21:59
  5. Weather Warnings...
    By R-man in forum General Chat
    Last Post: 26th November 2005, 10:34
