Thread: Signum stalling please help!!
    Jun 2009
    Liverpool
    Default Signum stalling please help!!
    Guys, any advice appreciated................
    Went out this afternoon as normal drove about 5 miles to drop kids off, stopped car took kids in got back in car drove off and car engine cut out after about 1/2 mile with a spanner/car showing on the dash. Waited a minute or so, car started up again but cut out again after a couple hundred yards. Kept doing this so abandoned car, nightmare day!!
    It has never done this before or had any warning that something could be wrong. It is a 2.2 direct on a 05 plate if that helps.
    Please help, really messes our life up with no car!
    Geoff
    Is it fine on tick over? just when you try to accelerate?
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    I could be wrong here but I believe a bad fuel pump or fuel pressure regulator is common to go on the 2.2's...
    preston
    if youve got a fault light, then there will be a code stored,
    do you know if anyone has a code scanner nearby?
    what about crankshaft sensor? these seem to cause all manner of problems ?
    i'd suggest a code read before you proceed
    good luck
    Jun 2009
    Liverpool
    The car runs fine until it cuts out, its a though there is some sort of immobiliser cutting the power? Can't believe it's just happened randomly?
    preston
    does sound a bit like a sensor fault....
    anyone else an ideas
    You need to get the codes read really. Could be any number of things
    Jun 2009
    Liverpool
    Thanks for all the info guys, there is an independent vauxhall specialist locally (Vauxcare, Wirral) so I think it best to try and get it there on their diagnostics.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Sure there must a some member near you with op com? that would be willing to help.
  1. Signum 2.2 Direct T Losing Power/Stalling....?
    By Buzzby in forum Engine & Drivetrain
    Last Post: 3rd August 2010, 10:08
  2. Car stalling
    By rob123 in forum Diesel Engine related
    Last Post: 29th January 2010, 20:25
  3. stalling in neutral
    By woodylove101 in forum Engine & Drivetrain
    Last Post: 30th June 2008, 19:55
  4. Stalling
    By MrBond in forum Vectra C / Signum Troubleshooting
    Last Post: 15th March 2007, 12:50
  5. 1.9 CDTI stalling
    By OilBurner in forum Engine & Drivetrain
    Last Post: 19th January 2007, 14:09
