Results 1 to 10 of 13
Thread: Probably need to get the radiator replaced.
    ireland
    Default Probably need to get the radiator replaced.
    I have a leak in the bottom left hand corner of my radiator as you face the front of the car. I need to put about ½ litre of coolant/water mix in every 3 weeks or so. I’m nearly sure I have to replace the radiator as the leak is quite noticeable along where the plastic and metal meets. Its like the metal has corroded and I can see the fluid forming at the bottom of the rad.
    My question is do I need to replace the radiator or is there anything that can be done to save the existing one?
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    Seems common, sadly its a new rad needed..
    Devon
    101 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Same as mine when i park up i can see a wet patch just under bumper lip and coolant has been going down slowly
    Irmscher Insignia CDTI 130
    Jul 2009
    The Rift, Cardiff
    Mine was the leaking from the same place but only as steam/vapour. A new radiator is the only way to go imo. I personaly would not use rad weld or similar.
    Regular Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    35 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 256,000
    Is radiator replacement a difficult DIY job? I think mine has gone the same way as you describe above.
    Paul
    ireland
    Its a fairly straight forward job, but will take some time if you have not done anything like it before.
    I bought the Haynes manual and it took me through the steps, it covers everything.
    You need axel stands to take the rad out through the bottom.
    I would recomend you buy the Haynes manual and see from what they say if you thinkn you will be able to do it.
    swansea
    Buy a recon one.
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    half a pot of ground ginger job done cost 17p lol
    35 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 256,000
    Cheers, guys. I enjoy working on cars and have been doing so and restoring classics for about twenty years, on and off. I have the Haynes but it doesn't cover the GSi. But looking at it, it doesn't look to be a difficult job.
    Just got to get the radiator now... Any suggestions?
    Paul
    ireland
    I got my rad from http://www.northernradiators.co.uk/
    It worked out the cheapest when ordering from Ireland.
    Delivery cost may affect your choice if you reside in England.
  1. Intercooler radiator removal without water radiator
    By Whosane in forum Vectra C / Signum Troubleshooting
    Last Post: 5th December 2012, 15:48
  2. Any one know where I can get DMF replaced in Blackpool???
    By colalowe in forum Engine & Drivetrain
    Last Post: 10th September 2012, 09:56
  3. What do I need replaced
    By m20_swe in forum Engine & Drivetrain
    Last Post: 25th March 2012, 08:45
  4. any one replaced the ecu?
    By twaiter in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2011, 23:44
  5. maf replaced still need help
    By scutster in forum Engine & Drivetrain
    Last Post: 15th May 2010, 10:16
vectra 3:2 gsi leaking radiater
vectra c radiator side plastic part leaking
radiater of job 10 th
