Thread: PC's for sale
    Apr 2006
    Quinton
    Default PC's for sale
    Hi,
    As we're moving house shortly (hopefully anyway ) I am having a bit of a technical clearout.............
    AMD Athlon XP 3200
    1gb ram
    200gb hd
    upgraded graphics card
    dvd rewriter
    wireless internet card
    in a funky silver case
    17" crt monitor
    £300
    AMD Athlon 1700
    256mb memory
    30gb H/d
    dvd rom
    multi card reader
    17 "crt monitor
    £125
    Also got 'several' 17" crt monitors lying around £20 each
    Open to serious offers on all of the above
    got some other bits and bobs such as CPU's knocking around if anyone's in need of parts
    Enjoy
    Nick
    Apr 2006
    Quinton
    ok, no takers at that price.
    how about £280 for the bigger one and £100 for the smaller??
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    what is the spec on the 17" monitors u have mate?
    Apr 2006
    Quinton
    hi mate,
    spec is .............. as found here:
    http://www.inmac.co.uk/catalogue/ite...e&lead=froogle
    Weight: 15.5 kg
    Depth: 41.7 cm
    Width: 41.1 cm
    Height: 36.2 cm
    CRT Type: Shadow mask
    Compatibility: PC, Mac
    Display Type: Display / CRT
    Manufacturer Warranty
    Service & Support: 3 years warranty
    Service & Support Details: Limited warranty - parts and labour - 3 years
    Power
    Voltage Required: AC 110/230 V ± 4% ( 50/60 Hz )
    Form Factor: Integrated
    Power Consumption Stand by / Sleep: 8 Watt
    Power Consumption Operational: 85 Watt
    Expansion / Connectivity
    Interfaces: 1 x VGA - 15 pin HD D-Sub (HD-15)
    Image Colour Temperature: 9300K, adjustable
    Video Input
    Analogue video Signal: RGB
    Miscellaneous
    Compliant Standards: Plug and Play, FCC Class B certified, CE, MPR II, CSA, UL, cUL, DDC-1, DDC-2B, DEMKO, EPA Energy Star, FIMKO, NEMKO, NUTEK, SEMKO, VESA DPMS, VDE
    Cables Included: 1 x VGA cable
    Environmental Parameters
    Min Operating Temperature: 0 °C
    Max Operating Temperature: 40 °C
    Humidity Range Operating: 20 - 80%
    Display
    Dot Pitch / Pixel Pitch: 0.23 mm
    Controls / Adjustments: Brightness, contrast, H/V position, H/V size, rotation, trapezoid, convergence, degauss, colour temperature, parallelogram, pincushion, pin balance
    Max Sync Rate (V x H): 130 Hz x 72 kHz
    OSD Languages: English, German, French, Italian, Spanish
    Video Bandwidth: 110 MHz
    Display Screen Coating: ARAG screen treatment
    Viewable Size: 16"
    Interface: VGA (HD-15)
    Diagonal Size: 17"
    Max Resolution: 1280 x 1024 / 67 Hz
    Regular Member Robbieben's Avatar
    Dec 2005
    Polishing a car somewhere
    You have a PM Nick
    Apr 2006
    Quinton
    you have a reply robbie,
    pc's still for sale at the mo
    Apr 2006
    Quinton
    Just for info the cpu on the bigger pc is a Amd Athlon 3200+ 64 (not XP as previoulsy written)
    Regular Member jonnye's Avatar
    Feb 2006
    Derby
    Nick,
    after a computer for my lad just to surf the net with, has the 1700 got a network card in it? also has it got XP?
    Also where in the midlands are you?
    Apr 2006
    Quinton
    hi mate,
    It has got a network card in it (lan connection) and has xp installed but as i didn't install it i don't have the necc licenses.
    I'm in bilston but happy to discuss halfway meets etc... to assist
    Nicking Ya Dinner.
    Nick, be carefull before you sell on either of them, make sure you 1st get all data shreded to a good secure standard, then to be safe reformat the drives at least another 3 times, flogging hard drives that have personal stuff on previously isn't a good idea, they're best off smashed up and burnt thb.
  1. Pad type PC's, which?
    By Grumpy1954 in forum The 'Off Topic' room
    Last Post: 4th October 2012, 21:21
  2. Custom PC's
    By Rebellion8878 in forum General Chat
    Last Post: 19th October 2010, 11:49
  3. Replies: 1
    Last Post: 5th May 2009, 11:35
  4. My old modded pc's
    By Morephun in forum The 'Off Topic' room
    Last Post: 16th July 2008, 11:08
  5. Replies: 12
    Last Post: 7th June 2007, 12:54
