Results 1 to 10 of 11
Thread: quick vectra b question
    Regular Member shoota70's Avatar
    bristol
    Default quick vectra b question
    sorry if posted in wrong section but in a bit of a rush =) looking at car on ebay with an hour to go
    father-in-laws vec b 2.0 sri (140bhp) has had its day and he has spent alot of money on it so is looking to get another vec b in good condition and strip the knackered 1 down and keep the good bits.. he is looking at a 1.8 sri (120bhp) my question is are all parts interchangeble engine wise and exhaust or does he need to stick with a 2.0 (140bhp)
    Jan 2010
    Liverpool
    Most things are interchangable as long as the 1.8 is a X18XE and not a X18XE1 iirc.
    The obvious things like major engine parts will not be swappable, though.
    Whats wrong with the 2.0?
    bristol
    its gonna cost a bit to get it threw the mot and he has spent £800 quid on it in the last year so doesnt really wanna waste all the new bits he has bought if that makes sense so he wants to buy 1 in good nick as he likes em and just have all the spares to hand like exhaust, radiator and other things
    Jan 2010
    Liverpool
    Most things are interchangable across the 1.8 and 2.0. One thing to note is the 1.8 has four stud wheels whereas the 2.0 has five stud.
    If fancy wheels are concerned then the hubs and brakes from the 2.0 can be fitted to the 1.8.
    The EGR system may be different, I had a SRi 140 that had no EGR system at all and the exhaust manifold was blanked where it would normally be fitted.
    I can't see there being any difference in the radiator. The exhaust from cat back will fit no problem, the downpipes should also be the same if its a X18XE. I'm not sure about X18XE1. Did the Vectra B get a Z18 engine?
    bristol
    will the cats be the same as he has had 1 of those fitted recently aswell as a water pump
    Jan 2010
    Liverpool
    The cat is attached to the downpipe, if the 1.8 is a X18XE then it should be the same. What year is the 1.8 he's looking at?
    Water pump may be the same.
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    The facelift vectra b uses an x18xe1 or a z18xe
    The x20xev engine is completely different to these 2 so unless its a pre 99 x18xev then no engine parts will fit..
    Jan 2010
    Liverpool
    Quote Originally Posted by alanv6 View Post
    Aye. The X20XEV and X18XE are very similar. I know the X18XE1 was quite different, but wasn't sure when the Z18 appeared.
    bristol
    Jan 2010
    Liverpool
    That should be a X18XE1. Engine is pretty different to the 2.0.
  1. Quick Vectra Question!!
    By Monkgti in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2013, 01:13
  2. quick hid question
    By chrislloydie in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2012, 15:26
  3. just a quick question :
    By booner in forum Suspension, Wheels & Brakes
    Last Post: 23rd November 2011, 20:22
  4. Quick Question - Need a Quick Answer if Possible
    By RobW in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2011, 23:55
  5. Quick question
    By sy_uk in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2008, 13:18
