Thread: Japanese Knotweed
    Regular Member Swatty's Avatar
    Jul 2006
    greenock
    Default Japanese Knotweed
    We are looking to extend the site I mange. One of the hoops we went through was to get an environmental team in to check there were no lesser spotted something’s inland we were hoping to build on.
    No problems with rare or protected animals/plants but we found out that there were a few areas with Japanese Knotweed on it.
    • It can grow by 10cm a day
    • The stem can reach three meters high and can move up to seven meters away from the plant
    It’s a menace and looks like a pig to get rid of - it can damage tarmac and concrete
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    if you dont know dont touch wait till someone tells you what to do
    Jul 2009
    The Rift, Cardiff
    It's illegal to move soil contaminated with japanese knotweed so probably best to contact your local council. One of the most punishable 'wildlife crimes'.
    Ashington, Northumberland
    Hmmm, horrible stuff. Reportable too, if you happen to find it you must report it. There's some fancy chemical they use and it takes a few goes I think. They used to remove the topsoil to a certain depth but I think that practice has stopped now.
    Essex
    29 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    Mileage : 97000
    As been said above.needs to be reported to the enviromental ppl.This can only be tackled by specialllist
    Jul 2006
    greenock
    We are going down the official route with it – have been following the guidance on the government web site.
    According to the advice so far you are not meant to build within 10 meters of any growth. If you are removing it you need to take away a fair bit of the earth around it – as well as going quite deep. Could end up being a significant cost (treatment and landfill)
    It is a real pest of a plant – which is reflected by all the rules about how you have to deal with it. I did not know there was an issue with a plant like this – thought I would pass on the info to the members.
    Oct 2010
    northampton
    horrid stuff i seen a grand designs or something like this with it on the land they were using and the clean up before they could build run well into thousands and thousands
    preston
    like many weed pests they can regrow from root fragments.
    i've heard of people cutting the stem then injecting weekdiller directly into the stem...... obviously this takes a while to kill to the root......
    and you would need to use specific weedkiller
    best to get proper advice....
    Jun 2007
    Wirral
    The proper method is to dig a huge pit, fill with the Japanese Knot Weed then pour on petrol and burn for three days, sprinkle with weedkiller, bury in concrete, and then top up the hole.
    Then move!! ;-)
    I think the main tactic is to bury the roots under a thin sheet of copper after it has been nuked with weedkiller but its been years since I was involved with it.
    A predator insect is being tried on Knotweed in some parts of the UK so the situation should get better eventually.
    Oct 2007
    Shropshire
    Flood the area with kerosene. Really saturate the ground. Nothing will grow including the knot weed. You may get fined for the oil though!!
  1. Japanese scientists
    By bobssignum in forum Comedy & Humour
    Last Post: 19th November 2010, 17:54
  2. Japanese GP -
    By Stevel in forum General Chat
    Last Post: 30th September 2007, 15:48
  3. japanese scientists
    By dazzer t in forum Comedy & Humour
    Last Post: 22nd April 2007, 22:00
  4. Japanese Scientists
    By AJA in forum Comedy & Humour
    Last Post: 27th March 2007, 08:03
  5. Japanese Proverb
    By vectra 2.0 t in forum Comedy & Humour
    Last Post: 19th February 2006, 21:31
