Thread: New brake light bulb
    Cool New brake light bulb
    I've just put a new bulb in my n/s brake, and it wouldn't work while testing it with the ignition on, so i tried 2 more and they wouldn't work either and my dash light warning was still showing i had a bulb out, thought sod it and went for a drive, when i braked the dash light went out and brake bulb seems to be working, why wouldn't it work when i tried a static test? Ta
    Feb 2006
    Dorset
    Can-Bus is playing pranks on you , the little electronic scampster ......
    Can-Bustard
    Melbourne, Australia
    Try checking with your headlights on. The same bulb is used as a second tail light, and it makes it much simpler to check for correct operation.
    Ta Stevedee.
  1. Rear brake light bulb warning won't go off
    By tomo41 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd May 2012, 21:39
  2. what bulb for brake light?
    By dannydm1 in forum Electrical & ICE (including SatNav)
    Last Post: 26th August 2011, 00:56
  3. Brake bulb warning light
    By SeeDeeXeye in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2009, 02:42
  4. rear brake light problem, bulb ok, please help
    By circushead in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2009, 18:29
  5. Brake bulb warning light
    By steve1975l in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2008, 19:11
