Results 1 to 3 of 3
Thread: misfire at idle
    Nov 2010
    walsall
    Default misfire at idle
    hi to you all im new at this and hope you can help me. i have a vectra 2.0 t 100 limited edition its started misfireing at idle but seems to go when driving then noticable when you try to put your foot down someone suggested the coil pack but i would of thought it would do it all the time any help much appreciated.
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    So would I but you never know. Have you done the simple things first like put a new set of spark plugs in?
    Central Scotland
    You wont get a definitive solution just on that description mate.
    Many, many things can cause a misfire, or what feels like a misfire. Is it a misfire or is it lack of fuel? You probably don't know yet which is why it needs to have a full diagnostic ran.
    Misfires can often be diagnosed wrongly without having manufacturer specific diagnostics plugged in. From your brief description it could be -
    Plugs
    Coil pack
    ECM
    Wiring
    Sensors (one or more of many)
    Fuel pump
    Fuel blockage
    To replace all the above you'll be over £1000, search locally for someone with Tech2/vaux com/opcom and spend £30 - £70 getting the fault pinpointed.
  1. Misfire at idle
    By mechman458 in forum Engine & Drivetrain
    Last Post: 12th March 2012, 14:13
  2. Vectra C 1.8 SRi Misfire when idle? HELP PLEASE?
    By shaine415 in forum Engine & Drivetrain
    Last Post: 25th February 2012, 15:52
  3. Slight misfire at idle
    By Lozza in forum Vectra C / Signum Troubleshooting
    Last Post: 17th June 2011, 06:52
  4. 2.0 turbo vectra low idle maybe misfire??????
    By vectra100turbo in forum Engine & Drivetrain
    Last Post: 1st February 2011, 17:36
  5. Misfire - even at idle when hot
    By muctm in forum Engine & Drivetrain
    Last Post: 13th June 2008, 12:07
