Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Finished my Exhaust/Oil Catcher/EGR Mod :D
    Regular Member vectraboyy's Avatar
    Default Finished my Exhaust/Oil Catcher/EGR Mod :D
    As of late i have been pretty dormant with the vectra, so i thought i would have a lil splurry on spending
    So i have bought the following goodies,
    - New Exhaust
    - New VXR real bumper insert
    - Toyosport Oil Catcher
    - Some silicone Vacum hoses
    - Silicone Intake hoses
    - EGR valve modification.
    Note, I, Vectra-C.com and any other Forum in which this appears accept no responsibility for any damage caused to your vehicle using any of the information provided in the post below or this thread.
    First - EGR Modification (1.9 CDTi 150bhp).
    The parts:
    Tools and bits needed:
    Carb Cleaner
    10mm Socket
    13mm Socket
    Simple task,
    Remove the electrical module on the EGR - don't turn the ignition on or the fault light will appear and you will have to have it cleared.
    Remove the two 13mm bolts
    Then remove the four 10mm bolts The two on the left hand side are double nutted theres two nuts holding a bracket on, then two underneath that bracket holding the EGR on. MAKE SURE YOU REMOVE BOTH or when you try to pull the EGR your snap the manifold..
    I now cleaned the EGR with carb cleaner, and scooped out the crud from the manifold (Mine wasn't that bad).
    Pop the new gaskets in and use a lil gasket sealant if you wish.
    Put the EGR on in reverse of above and then ensure you connect the electrical plug on it BEFORE starting the ignition.
    Job Done.
    N.B On some versions, the firmware for the EGR may trip the fault light after this mod. The simple solution is to remove the small oval shapped gasket.
    (mines a 2007 and it DIDN'T trip it)
    Second - Silicone Time!!!
    Previously installed:
    The Hoses:
    The small one is the 4mm Vaccum Hose.
    The large one around the edge is the 13mm Oil resistant silicone hose for the oil catcher tank.
    Fitted:
    They just went straight on in place of the old ones, for the vacum hose you only need about 0.5m but its only really possible to get 1metre lengths. therefore i have enough to do another car if anyones interested!
    Third - Rear Insert
    The bootiful VXR rear bumper insert,
    Lovingly sprayed in Sapphire black by me!
    (It wasn't finished when that picture taken)
    The Exhaust:
    Ready for the new exhaust.
    Now installed.
    The exhaust to go on was a second hand twin exit cat back from a 2.2 vectra.
    First i started by removing the rear valance, there are four clips holding it on underneath, which require a push up the middle and a lil tug to get off.
    Once there off you can get the unit off, i used a flate bladed screwdriver and slotted between bumper and valance and with a smooth, gentle pusing action eased it out, though this did leave some marks on the bumper, though these will be concealed with the new insert.
    Once that was donei jacked the car up.
    Personally, i only jacked and supported the passenger side REAR jacking point up. I found this to give me enough room and a good angle to be able to get to everything easily. I left the jack in place but not fully up as a precautionary measure.
    Next, i loosened the bolts on the rear silencer bracket, and the bracket on the cat.
    i used GT85 [WD40 equivelant] and sprayed the rubber hangers.
    This eneabled me to slide them off and with the loosened bracket, ease the rear silencer off.
    I found twisting it helped alot rather than just trying to pull it off.
    With the silencer off, i then got around to removing the centre section.
    with the bolt loosened on the bracket, i removed the two rubbers attached to it. this allowed it do effectively drop down.
    From the rear of the car i twisted the pipe whilst pulling and this motion seem to free it up quickly and then it came off.
    Now i set about putting the new pipe in.
    Firsty i laid the pipe under the car (Make sure its the right way around - don't realise this after you have got the put it in.....)
    i used exhaust pasted around the joint, and on the centre pipe a new bracket. i slid it in as much as possible, and then from the rear of the car again, wiggled it whilst pushing, not to hard though!
    Next, put the rubbers on the longer hangers on the boxes. The two middle located ones (From memory).
    Then the rubbers on the Car on the other two.
    I found this to be easier, as tryin to put the manipulate the rubber once its on the car and your trying to put it on the long hangers on th silencers is very hard.
    With the rubbers on the car and box, i slid the boxes onto the Y-Piece and into place. (perfect alignement isn't key at this point).
    With box boxes on, i set about trying to align them.
    i used the jack to prop the boxes in place aligned then tightening the bolts on them more to hold them.
    I did this on both boxes, then using the jack again, i propped up the centre pipe, to allow me to get the rubber on (I couldn't physically support the centre pipe and try and get the rubber on at the same time especialy with it being so stiff.
    Once the centre pipe was firmly fixed, i checked and re aligned the rear boxes.
    At this point i noticed that my left box was hanging to low, i ended up buying a new hanger rubber to fix this.
    Once all aligned and fully tightened the rear valance can go on.
    From Top:
    (Still tryign to get it to click in properly :'(
    Info:
    I found the old clamps had been spot welded on the old pipe but not on the centre section being installed, therefore i needed a new exhaust clamp.
    GT85/WD40 helps millions to get the rubbers on!
    IF the exhaust isn't sitting properly check the rubbers, mine wasn't and it turned out it was purely the rubber had got soft and allowed to much down movement.
    Parts Required:
    New exhaust Clamp (58mm)
    Two new rubbers plus one rubber for the new silencer (There were two brackets on my centre pipe, but only one on the one going on)
    Exhaust Paste.
    Four new Clips that hold the splitter on.
    1-2 hours.
    Tools Required:
    15mm socket.
    Jack
    Axle Stand
    Flat headed screwdriver
    Somthing pointy to poke the clips through with (I used a pen)
    Oil Catcher:
    A bit of a nightmare!
    Tryign to find somewhere to fit it was the hardest part, it comes with everything you need bar fixings to the car.
    I visited B&Q and spent £9 on washers, bolts/nuts and a Bosch HSS drill bit.
    The silicone pipe isn't required as you do get some, my OCD however meant that i didnt like having two different coloured/types of pipe doing the same thing.
    So i spent money replacing it with a Silicone one on the input and then the clearer blue one on the output so that i could see if there was too much oiling up inside the pipe.
    The parts include a bracket, however in the vectra i could really find an easy place to fit it so i made a bracket up that extended the current one using brackets from Wickes.
    I used a angle bracket attached to the provided bracket to secure mine to the car, it is currenly held on by one bolt, though i will double this up and make sure its more secure. Its a pain to put a hole in the necessary places though due to the obstructions.
    Available Viable places to fit.
    I found the Red Circle the easiest place to install in as it had the most room, but it is the furthest from where it needs to be...
    One you have fitted it inside the car, the breather pipe (Highlighted) gets cut and this literally pops in the Circuit for it.
    There are other further options on this:
    You can ventilate to atmosphere instead of having a closed circuit.
    Inserting steel wool inside the catcher to further aide 'catching' the oil as it passes through.
    Each option has it's own advantages and disadvantages.
    Done!!!
    Big thanks to the following:
    Gazza4 - for help with the silicone pipes amongst many other vectra things!
    OPC - with Oil Catcher Issues
    My Gf for putting up with my spray painting in her conservatory/dumping my exhaust in her conservatory/getting up early to go to sheffield and helping with fitting the exhaust.
    Parts from: Ebay, GFS, Fiat, Merlin motorsport (online), AP Motorstore (online) and Halfrauds.
    Useful Part Numbers:
    Gaskets from Fiat:
    13205877
    13205878
    All In £8
    Vectra VXR Rear Insert: 9271537 (VX) List price is £50ish
    Oil Catcher; Toyo Sport - eBay and many other places - £30 delivered
    Silicone Hoses:
    Vaccum Hose ~(4mm x 1 metre)- £2 Delivered -Ebay
    13mm Oil Resistant Hose (1mtr) - £13 Delivered APMotorstore (online)
    90 Degree Bend 55mm downsizer Samco - www.merlinmotorsports.com (Excellent customer service)
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    great job there m8
    is this the exhaust i had a nosey @ on fleabay @ £300 ?
    Nopes, it was only £125
    From a Vectra 2.2 Direct.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Good work m8.
    Gazza4
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    Nice job! Nice writing!
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    Has anyone considered in a closed circuit oil catcher loop, mounting the oil catcher in the free space in the battery case, then tapping the pipework into the joint where it connects to the inlet ducting. A couple of holes through the side wall and some rubber grommets for the hoses to pass through should do the trick.
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    Excellent right up and top job
    Thanks OPC and Gazza4
    Engine : 1.9 CDTi
    Looks like you have been busy
    Regular Member Craig1985's Avatar
    harwich essex
    How does the fiat gasket benefit the egr valve?
  1. oil catcher - is it necessary?
    By dunkymunky in forum General Chat
    Last Post: 12th July 2012, 16:34
  2. exhaust finished
    By paulvectrac in forum Styling
    Last Post: 27th September 2011, 21:07
  3. Nearly finished !!!!
    By marky boy in forum Vectra C / Signum Car Chat
    Last Post: 7th June 2010, 15:58
  4. Well here's one finished!
    By John LE in forum Styling
    Last Post: 2nd April 2010, 17:25
  5. What do you reckon on this oil catcher
    By andsaw in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2009, 20:52
chat cather mod.
termostat opel vectra c 2.2 dti
vauxhall vectra 1.9 cdti swirl flap leak
opel vectra c 1.9 cdti business
z19dth vacuum pipes update
vauxhall astra 1.9cdti oil breather vacuum pump
picture vectra butterfly valve
