Thread: Using normal 95 ron petrol in my VXR..?
    Nov 2010
    Home
    Default Using normal 95 ron petrol in my VXR..?
    I understand that the VXR has a sticker on the inside of the petrol flap saying a min of 98 ron is recommended so i've been using 99 ron since I got it. Would I notice any difference using normal 95 ron? What are the consequences?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I filled up a VXR with 95ron and it ran fine.
    Regular Member gibbon7000's Avatar
    lincs
    you will notice a loss in power, over time might cause damage to injectors
    Leicester
    The Vectra VXR will of course run on 95 Ron fuel but as already stated it will lose power. The ECU on this car runs a map that learns from the fuel it runs on, basically if you are using 98 or 99 fuel, with each tank the ECU will advance the ignition and other parameters to ensure the car gives optimum power etc.
    As soon as you fill the car with 95 Ron fuel, the system resets itself and reigns everything back in, so the car will feel a little flatter, it will then take about 3-4 tanks to get back where you were. According to Stuart Harris who was the VXR brand manager, the Vectra VXR should never be run on 95 fuel. I have witnessed a VXR280 running on 99 pull 282 BHP on a rolling road, then fill up with 95, run for 50 miles and put back on the rolling road and then produced 259 BHP.
    I know that the above is about Vectra VXR, but Insignia has a very similar function so 98/99 fuel should always be used.
    I know other cars in the Vauxhall range have learning facilities but the Vectra VXR is the only one that actually makes fundamental changes.
  1. is this normal
    By andy_richmond in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2012, 08:57
  2. Is in normal?
    By Pulja in forum Diesel Engine related
    Last Post: 28th June 2011, 20:20
  3. is this normal
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2010, 08:04
  4. EGR - Does this look normal
    By Samdy Gray in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 11:14
  5. 3.2 v6 - is this normal
    By tjames in forum Engine & Drivetrain
    Last Post: 16th January 2010, 14:06
95 ron vxr
