hi all
Cars about to hit 50K (1.9cdti)
is there anything i should look at getting changed as prevention rather than cure?
i.e. timing belt/chain, egr, injectors etc etc
hi all
A 2008 on 50K
That is 25K per year
Assume one service every 8 months, just keep with the current service plan until the warranty expires next year
The only thing you need to add next year is a brake fluid change
At this time of year check the coolant gravity
50K? Try 123k![]()
Timing belt I personally let go over 60k, however if you feel you want to have it changed sooner than that then go get it done m8.
As long as you service her properly and keep and eye on the fluids - oil and coolant she should run ok.
Gazza4
Gdgd cheers lads
It's had 2 services in past 12 months, but going to change oil and fuel filter before winter sets in, oh an top up anti freeze
