Results 1 to 2 of 2
Thread: can I fit 235/45/17
    Regular Member signum junkie's Avatar
    Edinburgh
    Default can I fit 235/45/17
    Hi guys can I fit these to two of my wheels if the others are 215/50/17. I have checked on a tyre calculator and there if very little difference in tyre diameter only -0.62% even less than fitting 225/45/17 at -2.01%. Would these adversly affect handling?
    Sodding Typical on Sea
    The 235/45 will fit I asked and was told it would go on, the 7" wide rims are a tiny bit too narrow that in truth the tyre patch on the road will only be about 3>4mm wider than if you fit a 215/50.
    I didn't fit 225/45's for the very reason you citeas it is a diesel in my car and economy is the aim, fitting shorter tyres defeat the purpose by well,,, 2.01%
