Thread: Vectra 2.2dti wont start
    Oct 2010
    Jekabpils
    confused Vectra 2.2dti wont start
    Hello!
    Bought Vetra C 2002 2.2DTI few weeks ago. This morning, after few km riding, battery, ABS and TC (ASR) lamps in dashboard began to light. I stopped the engine to check, if the alternator belt is ok - it is, also the batery, and cannot start car anymore. It is only small "click" in some relay under the dashboard at starting and "F" in all riding data lines (range, consumt, speed....) in computer. All other is working well. Is it common or need to get error codes? Thanks!
    Sorry for poor english.
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    That sounds like the battery has had it. It will have enough power to supply the electronics but as soon as the starter motor tries to start the engine, the voltage will drop to low. Have you tried to start it with another battery?
    Oct 2010
    Jekabpils
    No, i didnt, but the battery "eye" is green (it means - full) and also tested it by special battery tester - its OK. Also the horn is powerfull, central lock works from 30m... Checked all basic problems for any car.
    Oct 2010
    Jekabpils
    Checked all fuses - OK. Any ideas? What could :""F" in all riding data lines (range, consumt, speed....) in computer." mean?
    Oct 2010
    Jekabpils
    Problem solved. No Contact in ABS ECU connection.
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Strange, but at least it's going again! I didn't think that would stop it starting.
    Oct 2010
    Jekabpils
    As I was told, Vectra has CAN BUS (2 small wires or smth. like that) througt all ECUs. If there is no contact in one ore one Ecu is out - all system stops. It was 5 min job with OP-COM reading failure. I already ordered one for mysef.
    Devon
    101 Post(s)
    Vehicle : insignia
    Trim : irmscher
    ive been told that too all so if you remove lets say a door the car wont start as there's a break in the canbus and the system shuts down
    Irmscher Insignia CDTI 130
  1. Vectra c 2.2 dti wont start
    By latif in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2013, 07:06
  2. signum 2.2dti run out of diesel now wont start ???
    By signum dti in forum Engine & Drivetrain
    Last Post: 2nd March 2012, 19:44
  3. 2.2dti died on motorway and now wont start
    By larann in forum Vectra C / Signum Troubleshooting
    Last Post: 18th June 2011, 22:17
  4. vectra c 2 dti wont start
    By ricky192 in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2009, 23:50
  5. my vectra wont start help please
    By raymond1711 in forum Engine & Drivetrain
    Last Post: 14th April 2008, 13:04
