Thread: Indicator fault
    Regular Member TopRod's Avatar
    Liverpool, UK
    Exclamation Indicator fault
    I'm having problems with my indicators. about 50% of the time my indicators cancel on thier own with out turning the wheel or some times just as I begin to turn the wheel. I've had the car back to vauxhall 5 times with this and they say they can't fault it. they must be blind this happens on every jorney I make.
    Every time I get it back they try to lecture me on the indicator stalk how it needs to be put all the way down or all the way up to stay on. That is not the problem though I am making sure that is what I'm doing and they still canel on thier own.
    Has anyone else had this problem and had it fixed by the dealers??
    Regular Member luke.oldham's Avatar
    Aug 2009
    manchester/stockport
    mine does the same mate and ive not got to the problem yet.i no theres two setting if you tap it up or down they flash 4 times and if you pull it all the way up or down there ment to stay on but mine dont most of the time.im going to take mine off this weekend and clean the connectors see if that sorts it.cheers . luke
    I also had the same issue, dealership reckoned the angle sensor was too sensitive
    However a few months later the CIM was replaced and the issue disappeared...
    As your car is a 2002 I would just put up with it, something will fail eventually and you can then either replace the angle sensor and/or CIM
    Equally, try removing the indicator stalk blowing the connectors clean then retest
    Aug 2009
    the cim is big money isnt it.hope mines not going
    Liverpool, UK
    I had a black 2007 SRi before this one and that had the same problem. after many visits to the dealer they finally replaced the sim and the problem was solved. I'm gonna go back one more time and state that I want the problem sorted, I wouldn't go back 6 times for nothing haha! If they have none of it then I'll write to vauxhall and complain I think.
  1. Indicator Fault
    By philc1210 in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2013, 23:50
  2. Fault indicator.
    By Saxman in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2010, 20:42
  3. vectra c indicator fault please help
    By SRIDAN in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2010, 22:13
  4. Indicator fault
    By Sp33dy in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2010, 03:34
  5. Hi All- NEED HELP WITH a Signum INDICATOR FAULT PLS
    By okanac in forum Introduce yourself.
    Last Post: 22nd June 2009, 21:36
