Thread: electric mirror fault
    Oct 2010
    Birmingham
    Default electric mirror fault
    i have a vectra cdti sri 2007. have a fault with the electric mirrors, the left hand side one works perfectly but when i try and move the right hand side one, it still moves the left side. i knw theres a switch which allows to change between the two but when the right one is pressed in its still the same.
    any1 got any ideas??
    cheers
    Mileage : 000
    It is meant to work like that. There is nothing wrong with it. Adjust the right first, then the left. Then if someone else drives the car and needs to move the mirrors then they will both move together.
    If only these cars came with some form of manual that explains stuff
    Sep 2010
    I actually booked mine into the dealer with this fault and had to go through having the mechanic look at it and then advise me this was normal operation,... can't understand why the front desk staff don't know these things!!
    Oct 2010
    Birmingham
    what do you mean by adjust one first then the other? aint the switches for left and right suposed to let you select which mirror to move?
    Sep 2010
    nope, two switches yes but left one operates singularly and drivers side does both for the reasons posted above
    Oct 2010
    Birmingham
    ok will give that a go later on.
    thanks for quick replies
    Grantham, Lincolnshire
    63 Post(s)
    Trim : SRi (Rather Modified)
    Engine : 2.0T Maptun (240bhp)
    Strangely, it's not the case on all Vec C's (although does seem to be on all facelifts). I had two pre-facelifts at the same time for a while, an 03 plate SXi and a 54 plate SRi and one of them did exactly as you describe and one worked independently of each other.
    Quote Originally Posted by Ian-Highlander View Post
    Was the 54 plate fullcan by any chance?
    Oct 2010
    Birmingham
    still aint got it 2work. only the left 1 is movin by pressing either switch
  1. electric mirror
    By silky in forum Electrical & ICE (including SatNav)
    Last Post: 7th October 2012, 15:22
  2. Electric interior mirror
    By portreathbeach in forum Electrical & ICE (including SatNav)
    Last Post: 15th March 2012, 19:04
  3. electric mirror fault
    By beakster in forum Electrical & ICE (including SatNav)
    Last Post: 27th November 2009, 19:54
  4. Electric door mirror....
    By swirl80 in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2009, 15:26
  5. Bust electric mirror
    By bobsmith in forum Bodywork & Interior
    Last Post: 11th February 2007, 16:50
