Results 1 to 10 of 15
Thread: Box & DPF
    Mar 2010
    Sweden
    Default Box & DPF
    Allright, I've been reading a lot of post about fitting a box...
    But it seems that when I have DPF on my Vec, I shouldn't install a box (because it will kill the DPF) but go for the OBD-remap, or??????
    Aug 2006
    EVERYWHERE
    A lot of the time it depends on driving habits and how far up you have the box turned. But boxes are well known for blocking up filters even when the car is used hard and the box is adjusted correctly.
    The DPF can only cope with so much soot input before it cries enough.
    Better to get a remap and make sure, even then, that you don't do too much low speed, high gear fuel saving type driving because this keeps the exhaust gas temperatures too low and the soot output relatively high.
    There is the option of removing the DPF, but in many cases this seems to cause more problems than it solves.
    May 2010
    woking
    What problems are caused by dpf removal? It makes the car better and more reliable is this a problem people don't want a more reliable car?
    Aug 2006
    EVERYWHERE
    Quote Originally Posted by lgtuk View Post
    Environmental.
    But seriously (not that environmental issues are not serious) there have been loads of issues with the mapping software for DPF removal, particularly if your car has already been remapped. Which probably explains why it hasn't really caught on yet.
    I don't think that car manufacturers put these things on their cars in order to make them deliberately unreliable. There must be another reason?
    Mar 2010
    Sweden
    Alright, so if I mostly commute to work, I shouldn't go with either?
    Aug 2006
    EVERYWHERE
    Quote Originally Posted by Jabbekot View Post
    It's up to you bud, but if you don't need the extra power........
    You could get the whole lot mapped out (see other thread), but you would need to get someone to remove the filter either just before or just after the remap is done.
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    If you want more power and more mpg Mas performance do a stage 1 remap with dpf removal and egr removal software for 250 at your door I'm getting it done on wed but I have already removed my dpf myself so that was free and you will never have to worry about your dpf again
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Could you not get your car on a rolling road Winnie? Would be nice to see before and after graphs as i'm sure people would like to know what improvements the map will make.
    kings lynn, norfolk
    Won't get chance mate as it's on wed but will get one afterwards as I would like to know what it's running at
    Mar 2010
    Sweden
    The problem is that i live in Sweden... But we have a company called BSR. They do OBD remap and take over the engine warranty, but the charge £1000....
