Thread: ABS and Airbag Lights
    Sep 2009
    Harrow
    Default ABS and Airbag Lights
    Hello,
    I have 2 problems, ABS and Airbag lights are on and can't switch them off.
    But first let me tell you how those problems started:
    ABS - at first i heard a rumbling noise at the front left wheel and as someone suggested that it might be the bearing i bought a new one and replaced it. As soon as i replaced it the ABS light came on.
    Airbag - this one just came on without a reason.
    Yesterday i got a OP-COM cable and tried to clear the fault codes but the lights just go off for a second and then light again.
    Here are the DTC found :
    B0015 - Driver Pretensioner Circuit High Resistance
    (0D) - Present
    C0035 - Front Left Wheel Speed Sensor Circuit High Voltage
    (01) - Present
    I hope someone can give me an advice on how to remove those faults and/or how to repair them.
    Thank you
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Was the wheel bearing a cheap one or a genuine VX one? A few members have had this fault with cheaper replacement bearings.
    As for the air bag light, it sounds like your seat belt pre-tensioner has activated. Is the bit where you plug the belt into at the same height as the passenger one?
    Engine : 1.9 CDTi
    The pre tensioner plug can get unplugged if you slide the seat fully back.
    Look for a yellow plug/loom that isnt fully plugged in under the seat.
    Sep 2009
    Harrow
    This was the wheel bearing: http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=330394660166. And yes, the seatbelt sockets are at the same height.
    Engine : 1.9 CDTi
    I take it that one is for your car as they list 2.
    Sep 2009
    Harrow
    Is the one with IDS because the VIN number is larger the 51000001
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Does your car have IDS? (sport button)
    Sep 2009
    Harrow
    Is a 2006 manual 1.9cdti 150. It doesn't have a sport button. Are there manual transmission with a sport button? i bought that one because of what the auction says: "VEHICLES WITH IDS (Interactive Driving System)
    VECTRA AND SIGNUM WITH CHASIS NUMBER LARGER THAN 51000001"
  1. AIRBAG light .. is thier a fuse the the Airbag ecu ?
    Last Post: 10th September 2011, 13:21
  2. Airbag replacement - NSF (front passenger airbag)
    By Caveman_nige in forum Bodywork & Interior
    Last Post: 19th February 2011, 21:12
  3. Replies: 2
    Last Post: 31st March 2010, 13:30
  4. Philips bluevision h7 head lights & side lights brand new
    By davidlewis24 in forum Parts for sale
    Last Post: 19th March 2009, 22:42
  5. Dark lights and Rear Lexus lights finally fitted
    By Leviathan in forum Styling
    Last Post: 29th February 2008, 22:35
