Thread: Sqealing from drivers side of engine
    Oct 2010
    northampton
    Default Sqealing from drivers side of engine
    Hi guys i have had this noise a while but its getting worse i have a 2 litre dti 53 plate has anyone else had this and what solved it to me it sounds like it could be a belt roller bearing or something like that Regards steve
    Oct 2010
    northampton
    Now in Girvan Scotland
    Sounds like a drive belt or tensioner, get it checked or it may cause a severe failure and you may lose power steering or worse !
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Trim : SRI VX-LINE NAV
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 37000
    Auxiliary belt?
    Quite possibly, once had this go on an old 1.7tdi and it wrecked:
    water pump, belts (3), pulleys (2), tensioner, crankcase housing and metal housing mechanism !!!
    Sodding Typical on Sea
    Does sound like a tensioner has siezed either exposed on the drive belt or possibly internal on the timing belt, like others advise, take great care and have it checked ASAP
    Oct 2010
    northampton
    ill get it into my nephew asap then its not a bad squeal but i know its there
    milton keynes
    Does it get worse if you turn on the aircon?
    Oct 2010
    northampton
    noise gone just went away so i then just sprayed all around that area with gt 85 as an added extra
  1. drivers side window
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2010, 19:24
  2. drivers side, side reapeater
    By ks246 in forum Parts for sale
    Last Post: 26th May 2009, 17:31
  3. Sqealing noise
    By MalcGSI in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2009, 16:54
