Results 1 to 2 of 2
Thread: "diesel knock" sort of noise
    Sep 2010
    north east uk
    Default "diesel knock" sort of noise
    Or maybe a "pinking" noise.........best way i can describe this & having just had the car for over a month its the one remaining thing i have yet to find an answer for.
    Starts great, no spanner light, seems to be good mpg, also seems to have plenty of poke if its floored.
    But, when i start up from cold, set off (driving steady,not thrashing it) go into 3rd gear & when the revs get to around 1500 to 1700 rpm it makes this pinking sort of noise. Ease of the throttle by just the slightest ammount & the noise stops. Doesnt seem to do it when it gets to temp though (which takes a long time , but ive heard that this is a characteristic of the dti,s).
    Have read a couple of posts by members on this site who have had similar experiences with this, but dont seem to have resolved it.
    What i have done, Cleaned swirl flaps, egr valve, boost sensor with carb cleaner, was some split vacuum pipes to turbo wastegate & swirl flap actuators but renewed the lot with silicon pipe, oil & filter, fuel filter changed. ( since i replaced the vacuum pipes ithe noise is noticeably less than before)
    It made this noise before i did any of this work, so i dont think its anything i have done!
    Any comments or suggestions much appreciated........ really love this motor and this is the nly thing that getting on me nerves at the moment
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Mine does the exact same thing. It annoys me a little at times. However it has quietened down after adding some 2 stroke to the fuel tank. Not by a lot but it doesn't seem as pronounced now. Think it's just a characteristic of the DTi's.
  1. "Pinking" knock / rattle
    By pthres in forum Diesel Engine related
    Last Post: 29th April 2012, 17:50
  2. Lauder diesel "clacking" after clutch pressed 2.0 DTI
    By slimo1 in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2011, 13:43
  3. loud "thunk" noise from passenger side suspension
    By Gordon Livsey in forum Suspension, Wheels & Brakes
    Last Post: 10th October 2010, 15:14
  4. "clunk" noise when taking foot off brakes
    By sdnatlst in forum Handling & Braking
    Last Post: 21st May 2010, 19:13
  5. Vectra 2.2dti "grumbling/knocking" noise
    By Peetoki in forum Engine & Drivetrain
    Last Post: 17th February 2008, 14:51
how to sort out a diesel knock
zafira 2006 diesel pinking
2010 vauxhall zafira diesel diesel knock when cold
vauxhall dti diesel knock
