Thread: Resync your car key
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    Post Resync your car key
    found this little bit of info, not sure if it's been posted before..
    Vauxhall Opel Car Key Reprogramming
    Please note the following instructions are for re-synchronising remote keys. This allows keys originally supplied with the vehicle to be reprogrammed if they should go out of synchronisation with the car's code. Keys can go out of sychronisation if the battery has been changed or the button has been pressed numerous times out of range of the vehicle.
    It will NOT reprogram the remote facility on a newly supplied key or second hand from another vehicle.
    1. Sit in the car with doors closed. Place the key into the ignition and turn to Pos II (lights on)
    2. Now press the lock button on the key remote with the key still in the ignition for about 2 secs
    3. The central locking will now lock then unlock to show the remote control is now synchronized
    Additions: Vauxhall Opel models include Agila Corsa Astra Meriva Zafira Insignia Antara Vectra Signum
    Car Key Remotes are also referred to as Remote Plips or Remote Fobs.
    Sep 2009
    Glasgow
    if mine goes out of sync, it's only done this once, my fault, put key into door lock, open door alarm will sound and turn ignition to 2 and key good as new.
    Aug 2007
    North West
    Trim : SRI With a few added extras
    Engine : 1.9 CDTI 120
    Year : 06
    Cheers for that, mine does this and you have to open the car with the key, set the alarm off, and insert the key and get the ignition lights on before it shuts up, this is what I like, a nice, simple non-tech2 solution!
    13 Post(s)
    Quote Originally Posted by Caveman_nige View Post
    found this little bit of info,.
    This info is more for earlier Vauxhalls (eg, Astra-G, Vec-B and early Vec-Cs). Later Vec-C's is as nokiaman1978 mentions.
    The resync proceedure can also be found in the handbook
  1. key fob won't resync.
    By vegasbaby in forum Electrical & ICE (including SatNav)
    Last Post: 26th September 2012, 20:02
opel vectra c remote synchro
opel vectra c synchronize remote
re-syncing car key Vauxhall vectra
vectra c synchronise remote control key
