Thread: Heater Resistor Pack Help
    Regular Member manimal's Avatar
    Grimsby uk
    Default Heater Resistor Pack Help
    I understand that the resistor pack can be repaired with a part from Maplins for around 79p.
    What do i ask for & how do i fasten it on ?
    I've been told it is awkward to fasten it to the connectors.
    Anyone done this and would like to share there solution.
    Thanx.
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    ra23a you can either solder it on or cut the plastic of a electrical connection and connect that way you have to do two one for each side and you might have to file down the prongs a bit so they fit in the connector
    Grimsby uk
    Thanx Mate
    do you get much wire either end to play with ?
    Aug 2010
    Luton
    yes loads you end up cutting about 2cms one end and 4 cms the other
    Grimsby uk
    Thanx.....i get on with it in the next couple of days
    Aug 2010
    Luton
    just a tip when you get the glove box out of the way the resistor pack is bottom right to remove it, it slides sort of forward to unclip not down in fact it might be more towards the drivers side if you get what I mean
    Grimsby uk
    o.k. thanx mate
  1. Resistor Pack Replacement
    By EstateMan in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2016, 23:40
  2. Blower Resistor pack
    By jammy_c in forum Bodywork & Interior
    Last Post: 16th October 2012, 20:00
  3. Resistor pack
    By V6 JDT in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2009, 12:28
  4. motor resistor pack
    By timbarny in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2008, 17:17
  5. heater resistor pack
    By valhalla in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2007, 11:01
vectra c heater resistor
vectra heater resistor pack
