Results 1 to 3 of 3
Thread: Electric window help
    Regular Member manimal's Avatar
    Grimsby uk
    Default Electric window help
    Hi,
    i've had my vectra c drivers side electric window regulator welded because it snapped...done a good job of it too.
    It's been put back on the door, but i can't seem to get it to shut properly.
    When it gets near the top it starts leaving a gap(about 5mm) along the centre column side.If i hold the glass when i close it,it guides it shut.
    Anyone know how to level this up please,is there a certain way you have to do it ?
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi M
    it sounds like you have the weld slightly out of line,try to adjust the regulator by slacking of the bolt through the assembley hole,the glass has to be pushed up to the stop and back into the B pillar,then retighten the bolt while you hold the glass in this position. a squirt of WD 40 inside the slides helps also.
    Grimsby uk
    I'll give it a go.thanx
  1. Rear electric window help
    By RBH in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2013, 15:51
  2. Electric Window Woes!
    By VVT-i-MATT in forum Electrical & ICE (including SatNav)
    Last Post: 17th August 2012, 13:32
  3. Electric Window
    By treasure22 in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2011, 16:20
  4. Electric Window Help
    By Digital_kid in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2007, 18:58
