Results 1 to 10 of 15
Thread: Fuel Flap locking mechanism broken? Help please
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Exclamation Fuel Flap locking mechanism broken? Help please
    Hey all,
    2 months ago I went to fill up the car and found the fuel flap was jammed shut! Apparently a common problem with the Vectras? After much careful manipulation I managed to get the flap open and dismantle the mechanism.
    With the case open I found that the motor was spinning to lock, but there was smoke coming out when trying to unlock and the motor would just click once....
    Ordered a used part off ebay from a breaker and recieved it today... however its doing the same (uninstalled as I wouldnt want to risk jamming the flap again).
    Now I wondered as I cant open the casing this time as it would void the return policy...
    How does the lock work? There are two wires only... On first though I figured that the motor was a 2 way and can spin one way to lock, and the other to unlock?
    But with two wires, I couldnt figure out how this was possible without literally changing the input wire... which wouldnt make sense as it would mean changing the earth point lol
    Can anyone explain this otherwise simple system so I can fault find and check there is no fault with my vehicle.
    I have the Signum with the 2 button fob (whole car only) and no boot lock/unlock buttons on the drivers window switch panel
    Bordon, Hampshire
    None else had this problem yet?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Interesting fault you have, not heard of it before. I suppose you could assume that the one sent works and therefore the fault is elsewhere, where I don't know but as least its given you a bump
    Bordon, Hampshire
    Quote Originally Posted by merikiito View Post
    Thanks mate, found 2 other posts on here but they either don't answer it or aren't very clear. I ordered a spare second hand one in but same problem?
    From the other posts I read I need to:
    A) Check the fuse again...
    B) See if there is a relay for it and test (which there must be as I think there is only 2 wires... and in order to change the direction of the motor surely the pos/neg would need to be reversed...
    Anyone know if and where the fuel flap relay is???
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    its part of the REC
    Bordon, Hampshire
    I'm lost... whats the REC lol?
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    Rear electric center (rear fusebox), but the fuelflap, is also connected to the Central locking system, that is control by the Body Control Module
    Feb 2007
    North west
    when this happened to me i just fitted a locking fuel filler cap from hellfrauds and left the motor off.
    Bordon, Hampshire
    Did consider the locking fuel cap but don't want another key lol.
    Kenp - do you know if there is a relay in the REC or only a fuse?
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    its pure electronic... no fysic relay.
  1. Locking Fuel flap
    By tubby in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2012, 21:19
  2. misbehaving fuel cap locking mechanism aarrgghh
    By pogo in forum Electrical & ICE (including SatNav)
    Last Post: 30th April 2012, 14:51
  3. Fuel Filler Flap Locking Motor
    By jimmy495 in forum Vectra C / Signum Troubleshooting
    Last Post: 27th September 2011, 22:34
  4. Fuel Flap Locking Solenoid
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2011, 09:21
https:www.vectra-c.comforumshowthread.php122214-Fuel-Flap-locking-mechanism-broken-Help-please
https:www.vectra-c.comforumshowthread.php122214-Fuel-Flap-locking-mechanism-broken-Help-pleasepage2
how to replace zafira petrol flap locking solenoid
vectra c fuse 15 fuel flap lockinsignia fuel cap problemvuxhall vectra fuel flap lock motor removelvauxhall vectra fuel cap problemreplace vectra c fuel cap lock site:www.vectra-c.comcentral locking on fuel cap insigniainsignia fuel flap fusevauxhall corsa fuel flap does not lockvauxhall insignia fuel flap brokenVauxhall insignia petrol cap mechanismvauxhall fuel flap lock mechanism repalcementFitting petrol cap Vauxhall insignia corsa d fuel cap solenoid removalVauxhall vectra b fuel filler cap lockvauxhall vectra fuel cap solenoidvectra c 2004 petrol cap not lockingHow to remove central locking sensor for vauxhall vectra petrol flapcorsa fu flap motor replacmentvauxhall insignia fuel cap clip brokenvectra c fuel cap problemlocking fuel cap replace on insigniavectra c tank lock fuse location
