Thread: serviced gsi
    Regular Member stuart bigboy's Avatar
    May 2007
    kent
    Default serviced gsi
    just put car in for a full service all done . one adviserey both the front springs are broken has any one else had this happen to there springs and how much did it cost to get them changed
    Springs breaking is very common, mainly due to speed bumps, pot holes and maybe poor material construction of the spring itself.
    Front pair on my Signum was about £250, snapped on boxing day and no-one else could get any. Personally, if it happened again a set of lowering springs all round would be cheaper.
    Regular Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    35 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 270,000
    Yep. My driver's side spring broke on Easter Sunday a few years ago. I had Eibach Sport Springs fitted - same length (as SRI/GSI), I believe and similar rating but much better quality and heavier construction (thicker steel). The handling has improved as a result as well.
    Paul
    Regular Member Jezzy's Avatar
    S.E
    Fella, how is it possible that you're a Full Member on here and yet you haven't heard the many, many, many tales of broken springs? lol. Probably the second most common complaint, after "My 1.9 diesel is proving just a teeny bit problematic...."
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    My front suspension makes a funny noise when going over speed bumps, its like a noise when you sit on a leather sofa, its hard to describe really. How can you tell if there are cream crackered, as I have had a look at mine but can not tell.
    Quote Originally Posted by Jonsey View Post
    Its very clear if the springs are snapped - there is a bit missing you have 4 so there will be another one to compare the basic looks with.
    However yours is a different problem so should really be in a different thread. But, its either - drop links, arb bushes or the rad mounts.
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    Jonsey sounds like you have a problem with the Anti Roll bar Bushes or Link arms on the front.
  1. never been serviced????
    By rob warrington in forum The 'Off Topic' room
    Last Post: 3rd June 2010, 14:00
  2. serviced
    By fishaman in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2010, 20:57
  3. Just serviced.
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 16:52
  4. Air con serviced
    By jamalex33 in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2008, 16:56
  5. Serviced by vx at 58,861
    By ProfessorFalken in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2008, 13:40
