Thread: Total Vauxhall: CDTi tech assistance required
    Nov 2009
    Bath / Dunfermline
    Default Total Vauxhall: CDTi tech assistance required
    Hi chaps
    Been sent this question by a reader and we're hoping some of you CDTi owning chaps could shed some light on the situation?
    Dear TV,
    I have a Vectra C SRi CDTi 150, when you floor the throttle the engine comes on boost ok but when you hit around 2200 rpm it hesitates briefly before carrying on, this is more exaggerated in the higher gears particularly if coming up from lower revs where the hesitation lasts much longer. The inlet manifold, boost sensor and egr valve are new and I've examined the rubber vacuum pipes for leaks as much as possible, they sound like they are holding vacuum when removed. Is this hesitation normal? Any help greatly appreciated, Cheers.
    Thanks in advance
    Dave
    Regular Member In a states's Avatar
    Dec 2005
    In an estate car
    AMM at a guess
    Nov 2009
    Bath / Dunfermline
    That was along the lines I was thinking, but are there any basic checks to try and pinpoint any of the common faults. On the basis the EML isn't on (I assume) then a code read won't help however data list checks could give some information.
    Standard issue "Go to Vauxhall, get it Tech 2 checked" reply coming up I suspect!
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Hi, there's been a lot of members with very similar symptoms!, im pretty sure most have been throttle body related!, remove & clean the throttle body & (this is the main fault) remove the clips on the bottom housing gaining access to the elec side, if its filled with oil clean with elec contact spray, there's also a fault within the soldering, I will include the linky & hope this is of some use, Not everyone has fault lights with this! so can be hard to find,regards dek.
    http://www.vectra-c.com/forum/showthread.php?t=119346
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    As the throttle body is the only thing not done & he's describing hesitation this could be it, dave try searching for hesitation see what pops up! .
    Also maybe a third injector (wiring fault) although unlikely, it maybe worth checking out.
    Nov 2009
    Bath / Dunfermline
    Brillaint, we'll go down that route then (obviously referencing Vectra-C in the reply) so much appreciated again gents.
    Dave
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    DAVE! read this thread 10 pages BUT TAKE NOTE OF THE LAST!! RESULT & AS SUSPECTED!.
    http://www.vectra-c.com/forum/showth...ght=hesitation
    PS IF YOU GET ANY FEED BACK PLEASE LET US KNOW.
    Nov 2009
    Bath / Dunfermline
    Sorted, obviously we can't go into a huge detail in the magazine but a generic reply and then directing Vectra owners this direction and to the "search" fucntion is the route we'll be taking. May cure this chaps issue, may not but either way it'll give the forum a little free plug!
  1. Total Vauxhall Magazine: Technical assistance required
    By Turbodave in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2010, 19:34
  2. CD70 Navi Assistance Required
    By l.brown23 in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2010, 19:08
  3. Assistance required Visor monitor
    By esh42 in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2009, 20:50
  4. Urgent assistance again required.
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2009, 19:05
  5. Vauxhall Assistance
    By iain.condliffe in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2008, 12:42
vauxhall technical assistance
