Results 1 to 2 of 2
Thread: P1481 error code - can't fix on CDTI 120 Vectra C
    Nov 2010
    DENMARK
    Unhappy P1481 error code - can't fix on CDTI 120 Vectra C
    hi
    I have a 2005/2006 Vectra C 120HP diesel including partikel filter. I got the following code: P1481 and have of course searched the forums and google for help.
    1) Went to the dealer as the engine sign lighted up - they told me it was the left fan on the water cooler.
    2) Went to my own mechanic and we tested the fans on his test equipment. It showed that boths fans could run. Out of the 4 stages we could however not get 2 of the 4 speeds to work. Then our best suggestion was to
    3) Renew the electric between the two fans for the cooler as both fans could run. Did not fix.
    4) Should I now renew the very expensive left fan motor?
    kind regards,
    Peter
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Here is a wiring diagram for the controller of the fans.
    Have you checked both the fuses under the bonnet? F35 (50A), F36(30A) ?
  1. Vectra c air bag issue b1000 error code
    By Justns8293 in forum Vectra C / Signum Car Chat
    Last Post: 1st November 2018, 21:47
  2. P1481 fault code
    By stevedee3 in forum Engine & Drivetrain
    Last Post: 13th January 2016, 23:09
  3. Code P1481-P1482-P1483
    By Aikon58 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th July 2013, 12:30
  4. Vectra SRi C alarm keeps going off code error fault
    By Tapie in forum Vectra C / Signum Troubleshooting
    Last Post: 8th September 2011, 20:53
p1481 opel vectra c
p1481 hibakód
saab 93 diesel p1481-04 error code
https:www.vectra-c.comforumshowthread.php122185-P1481-error-code-can-t-fix-on-CDTI-120-Vectra-C
vectra p1481 -04
saab p1481
erro p1481opel
P1481opel vectra
Saab DTC P1481-04
vectra 1.9 cdti fault code p1481
p1481-04 saab 9-3
P1481 on an Opel corsa V
p 1481 opel
P1481 opel signum
1481 koja je greska
vectra c 1481
2003 vauxhall astra fault code p1481 fix
p1481-04 vectra c
p1481 opel corsa c
p1481 saab
error P1481-04 saab
