Results 1 to 10 of 16
Thread: Completely stumped
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    Default Completely stumped
    Totally confused to whats going on here.
    I am almost finished my kerblighting project and have come across a major problem.
    I have ran all my wires lights are fitted. My wiring is as follows...
    Rear doors earthed via door frame work. Front doors earthed via Brown earth wire on door loom as i cannot get an earth off the front doors for some reason.
    All positives running to brown/white wire on interior light.
    I have talked in length to Leemarksmith about this and have done as he has when doing his footwell lights.
    Now for the problem.
    It all works the opposite way than what it should. eg... when the interior light goes off the kerb lights come on and when the interior light comes on the kerb light go off.
    What has went wrong.
    Any clues??
    I have a plan B but i would rather have them working this way.
    Thanks in advance
    Keith
    Hanging Heaton
    27 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Quote Originally Posted by Keithy View Post
    Ahh, didn't realise that from PM's... but still
    Regular Member LADmachining's Avatar
    Hampshire
    The brown/white wire controls the interior lamp(s) by providing an earth (via the BCM).
    When the BCM switches the interior lamps off, the brown/white wire goes positive due to it being essentially open circuit at the BCM. +12V finds its way through the filament of the lamp into the brown/white wire. Enough current flows through the filament to illuminate you new lamps (I assume they are LED based).
    To fix this, you need to connect the new lamps to a permanent positive supply instead of earth (and observe correct polarity if the lamps use LED's).
    Jan 2008
    Dundee
    Quote Originally Posted by LADmachining View Post
    No they are OEM which are std 501's mate. So will i be safe enough to change the polarity at the door end? Which wire in the door looms are constant live?
    Hampshire
    If they are standard bulbs, the polarity will not matter.
    A permanent live can be picked up on the red wire going to the electric window motors. There should also be a live feed going to each door control module - this should also be red, but I cannot locate the circuit diagram at the moment to confirm this.
    Hanging Heaton
    27 Post(s)
    Mileage : 140k
    Just realised anyway... No help again but i did my mates the exact same way as i suggested and his are fine, so its definately not my ribbon issue why mine work the way you'd need them to...
    Plus i think Rushy used same feed for his footwells or was going to?...
    Free Bump.............
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by leemarksmith View Post
    Yea I did, but I think the wire is actually some sort of feed to the rear courtesy lights Lee as I can have it so only the footwell lights come on instead of footwell and courtesy just by pressing one of the buttons in my Elite/Police spec courtesy light cluster. i have the rear courtesy light as well if that makes any difference.
    Hanging Heaton
    27 Post(s)
    Mileage : 140k
    Thats normal tho mate, one of the buttons does turn the interior light off so does not come on with doors or the fob...
    White/Brown is one of the main feeds into the light thats why the same button wont turn your footwells off as your bypassing this switch... And you'd want kerb ones to do the sane.
    What keith's is doing is going off when interior lights on, then on when interior light goes out... Kinda backwards.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Hanging Heaton
    27 Post(s)
    Mileage : 140k
    Exactly lol..... Hopefully he's sorted it has he's not posted today...
  1. Stumped - Radio Code
    By UncleMelon in forum Electrical & ICE (including SatNav)
    Last Post: 14th December 2010, 10:04
  2. Fascia lights - completely stumped
    By Biggles in forum Electrical & ICE (including SatNav)
    Last Post: 23rd October 2010, 09:00
  3. stumped
    By tibrido in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd December 2009, 10:41
  4. This had me stumped..........
    By PeterVV in forum General Chat
    Last Post: 28th November 2009, 17:22
  5. Stumped!!
    By TonyR in forum Electrical & ICE (including SatNav)
    Last Post: 18th September 2005, 15:30
