not sure what exactly could the problem be, the temperature suddenly started to sit at around 80 at all times, rather than 90, and theres a definate smell of coolant coming through the airconanyone knows what this is? its a 3.2 v6, thnx
Thermostat stuck open? What's the coolant level like? Has it dropped? Could well be the oil cooler seals. The cooler sits in the middle of the vee so it's not that easy to see and check for leaks.
Mine did this when I first had it. No leaks but the thermostat was ******ed.
Pressure test the cooling system. Could be that you've got a leak, albeit a small one, and the smell of coolant is been drawn in from the engine bay.
I have the same problem, but with a 2.2DTi. I can smell coolant when I step out of the car...
thanks for the suggestions, will try to get it looked at today, BigSig, is the oil cooler an engine apart £700 quid job? i am pretty sure i had that changed less than a year ago, could that go again?
cheers
that would be it then, i had that changed less than a year ago. i think the thermostat, as BigSig said happend to him seems like the answer, just rang a garage and hopefully get it sorted soon, thanks
also give David A.K.A Judas a shout - he was recently having similar issues![]()
Think its deffo the thermostat, as the needle doesn't sit at 80, it barely moves of cold
