Page 1 of 6 123 ... LastLast
Results 1 to 10 of 58
Thread: Does blanking your EGR really effect the fuel economy.What do you think?.
    stockport
    Exclamation Does blanking your EGR really effect the fuel economy.What do you think?.
    I was just wondering if all those members who have blanked their EGR valves completely have found any difference in the fuel consumption/power etc.The reason I have started this thread is to determine if blanking has any adverse or can,indeed,as many members have posted,have a real beneficial effect,or is it just their imagination?.FELIXX.
    stockport
    Quote Originally Posted by felixx View Post
    stockport
    Arrow
    I cannot understand why this thread was never posted for viewing.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Feelix maybe you haven't given enoigh time for the correct people to respond.
    Gazza4
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    I have mine disabled via remap and can acheive 40-55 mpg, even managed 47 mpg with urban driving , a little painful tho.
    EVERYWHERE
    I've heard that blanking the EGR valve on a DPF equipped Vectra helps the 'economy' no end.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by diesel dog View Post
    What has that got to do with it?
    Gazza4
    EVERYWHERE
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    I'll explain.
    If you blank the EGR valve on a Vectra equipped with a DPF it will prevent the exhaust gases that burn off the soot in the filter from getting hot enough, thereby causing failure of the DPF and hence the requirement of a new one or a removal/remapping of one, hence the helping of the 'economy'.
    Theoretically, blanking the EGR valve will increase fuel consumption since neither the MAF or MAP sensor will have detected a change in inlet manifold pressure which would signal the ECU to alter injection timing and provide less fuel for combustion during the periods that the EGR valve is open.
    Have you got that?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Here we go again LOL. As my petrol doesn't monitor the EGR flow as such my findings could add a different twist on things as it looks like it comes down to the actual burn. With it blanked I suffer about -2 MPG. Its especially evident in the winter months to the point where I'm thinking of putting the EGR back on. I always make comparisons to my old Mini with a stage one kit. You could have a heated manifold for economy.
    stockport
    Arrow
    I'll explain.
    Have you got that?
    This is one of the main reasons I raised the question in the first place.When I originally fully blanked the valve I really did seem to use more fuel but put it down to the increased performance that was available and my "enthusiastic" driving.However,since fitting a new valve,and not blanking it,my fuel consumption seems to have improved dramatically.What I want to try and determine is whether it is my imagination or is there a connection.Would I protect my inlet manifold by semi blanking together with the ccv set up just as effectively as fully blanking?. FELIXX.
  1. Could blanking egr effect injection timing at all?
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 8th January 2013, 00:00
  2. Fuel Economy
    By nrestell in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2012, 20:56
  3. Fuel Economy
    By blee93 in forum Vectra C / Signum Troubleshooting
    Last Post: 29th April 2012, 20:32
  4. Fuel economy from a 1.8
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2009, 21:58
  5. Fuel Economy
    By Steven in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2007, 11:54
https:www.vectra-c.comforumshowthread.php122151-Does-blanking-your-EGR-really-effect-the-fuel-economy-What-do-you-thinkpage2
https:www.vectra-c.comforumshowthread.php122151-Does-blanking-your-EGR-really-effect-the-fuel-economy-What-do-you-thinkpage2#::text=If the EGR valve is oxygen in the combustion process.
egr blank fuel economyegr blanking fuel economy petrolegr blank off reduce mpgdoes.comblanking the egr use more dieselmercedes egr blanking platefuel consumption with blanked egr
