Thread: Permanent supply in boot?
    Oct 2010
    Lincoln
    Default Permanent supply in boot?
    Anyone know an easy place to pick up a permanent 12V supply in the boot of a 56 plate Vectra C? I know the fuse box is in there but does in unclip so
    I can to the back of it? Need the supply for a bypass and split charge relay. Ideally 30A as I'm using the supplied 25A in-line fuse to protect.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Theres a spare slot on the rear fuse box that's permanent, think its the the second or 3rd spare large fuse holder, just add a spade connector to the end of a wire, job done. Im sure there a how2 for that, i'll have a look. You putting in a 12v Aux Socket?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Try F3 in the boot mate. You should be able to put a large spade connector in the empty slot. 40amp I believe.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Jinx
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    Jinx
    Ditto
    Oct 2010
    Lincoln
    Thanks, no aux socket just caravan wiring. Would prefer to bung a fuse in and skotch the back, is there a way to drop the fuse box out like the Vectra B. That one just clipped off and you could get to the back of it.
  1. 12v permanent feed in boot needed
    By ijk571 in forum Electrical & ICE (including SatNav)
    Last Post: 1st January 2013, 19:30
  2. Permanent live in boot
    By montyfert in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2012, 20:11
  3. permanent live in the boot
    By Al 22 dti in forum Electrical & ICE (including SatNav)
    Last Post: 2nd June 2011, 07:02
  4. 12v power supply from boot?
    By Craig1985 in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2011, 23:24
  5. Permanent Live in Boot?
    By bandrew in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2009, 15:03
