Results 1 to 10 of 11
Thread: Pug 307 HDI - New battery but sounds flat
    Regular Member damers2000's Avatar
    Aug 2010
    Pontefract
    Default Pug 307 HDI - New battery but sounds flat
    Just a general enquiry really about my Dad's car.
    He recently bought a new battery for it but since the mornings have sarted getting cooler the starter motor sounds like its struggling to turn the car over.
    To me, it sounds like there is something which is draining the battery whens its parked up but I don't know. I only say this as when it's driving the battery light doesn't illuminate so I'm assuming the alternator is doing its job.
    Having said that, once the car has started, you can turn it off straight away and then start it up immediately after that and it starts fine.
    Any thoughts on this at all will help
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Defiantly get a voltage meter over the batter terminals to double check the Alternator is working ok, should be reading 13.5-14.4v with the engine running. After that it time to start looking at things like the boot light and glove box lights, if fitted. Often switches get knocked out of place or fail causing the battery to run down over night. Of course it could be a dodgy battery too, thats not holding the charge. Is it a sealed battery or an older style battery where you can top up with water? If its the latter check and see if the plates have got enough water.
    Aug 2010
    Pontefract
    Thanks for the pointers mate, I'll go and have a look at it for him when it finally stops raining. I don't think me messing with the battery in the rain would sort it! lol
    Cheers!
    Administrator plasma's Avatar
    On the Forum
    579 Post(s)
    Engine : 150
    Mileage : 74000
    also check the condition of the earth strap from the battery to the gearbox, plus also it could be the start of a weak/lazy starter motor
    Aug 2010
    Pontefract
    I've taken a meter reading off the battery while the engine is running and it's showing 14.4 so all seems to be fine there.
    I've checked all interior lights and they arn't staying on when the car has been locked so I'm fairly sure its none of those.
    I'm not too sure what else it could be as the battery is only 8 months old. battery is a bosch silver top.
    Could it be the starter motor? I have heard some people mentioning lazy starter motors but is there any way of testing it?
    Engine : 1.9 CDTi
    It could be starting motor or the glow plugs drawing extra current.
    Regular Member rjw's Avatar
    Oct 2010
    cornwall
    has it an immobiliser? i had a 306 HDi with a faulty immobiliser that drained the battery in about 6 hours of being left standing. eventually got a motor electrician to bypass the immbiliser!
    seanyy
    Guest
    Hi, did you get anywhere with the peugeot? Was it the starter motor? I have one and exactly the same problem. I completely recharged the battery and it still turned over like it was flat. So I tried jumping it from my Merc and it made no difference!
    Aug 2010
    Pontefract
    it's still the same at the moment, especially when its below freezing. I did get hold of a new start motor off ebay for it for just short of £60 so I just need to get it fitted.
    After reading umpteen threads I'm absolutely certain it's the starter motor, I'll be able to confirm it once I manage to get it fitted.
    Apparently, jump starting isn't ideal on the Pugs as it supposed to fry the BSI??? I don't know though as I did jump start the Pug once when the old battery did die and it still goes....
    Regular Member RLFH470's Avatar
    Nov 2009
    West Sussex
    Trim : SRi Nav
    Engine : 1.8 VVTi
    Mileage : 55k
    My wife's 2002 Citroen C5 2.0 HDI had exactly the same problem when the temperature dropped below freezing. Turned out to be the starter motor and a failed glowplug. Now that the starter motor and the glowplugs have been replaced it starts like a petrol engined car now and she reckons it drives smoother as well. HTH
  1. It sounds like I'm running on a flat!!!
    By IWC in forum Suspension, Wheels & Brakes
    Last Post: 22nd July 2010, 22:22
  2. flat battery
    By middler31 in forum Engine & Drivetrain
    Last Post: 20th July 2009, 20:55
  3. Flat battery and cicking sounds from fuseboxin boot
    By Stevo K in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2009, 15:18
  4. Flat Battery...
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2008, 00:58
  5. Flat battery, I think
    By Hideous in forum Engine & Drivetrain
    Last Post: 29th December 2007, 20:50
