Thread: Do i need a new hub?
    Jul 2010
    rotherham
    Angry Do i need a new hub?
    When i changed the brakes the other day i noticed they were only 4 bolts in my wheel. So i changed the brakes and everything and when i came to but the alloy back on, only 3 bolts would go in. The botton 3, so the top 2 have no bolts in at all becuase the thread is just messed up. Do i need a new hub for this as my mot is in about 4 weeks and will defo fail on this. Or can i just get the wholes re tapped/ re threaded.
    if i need a new hub wheres the best place to get them from becuase on ebay i cant find any for my car its a 2.0TDI
    13 Post(s)
    Firstly, you shouldn't be driving around with only 3 bolts holding your wheels on. The extra stress on them could make them fail as well.
    It depends on how badly the threads are damaged. You might get away with running a tap down the threads, or have helicoil inserts fitted.
    There must be a few Vec-C's and Signums in the breaker yards by now to source another hub from.
    Jul 2010
    rotherham
    Im not driving it i have left it at my girlfriends while i find out what to do. Im getting lifts of her.
    Iv bbeen to most of the local scrap yards and i found 1 hub but it was off at 3.2 petrol and they said that it would be a different size.
    Jul 2010
    rotherham
    Also when i changed my brakes the brake warning light is still on the dash? Do i have to get the fault codes cleared for this to get removed?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The brake warning light will still be on until you either fit a new wear sensor or cross the 2 wires together that go to the sensor.
    I though the hub was the same on every Vectra model / engine combination
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    First off try getting it re tapped this is very easy to do and a job any garage should be able to do in less than an hour, the hub off a 3.2 should be ok I cant think of any reason it would be different tbh as brake components are interchangeable over the entire vec range, maybe someone knows otherwise.
    Was the light on before you did the brakes? When you did the brakes did you change the Brake Pad Sensor wire going to the front near side caliper? If it was on before you did the brakes it means it has to be replaced or removed, they are less than £10 to replace, £7.54 from ECP. Replacing or removing will clear the light.
    http://cgi.ebay.co.uk/Vectra-C-Brake...1#ht_500wt_949
    Oct 2007
    Shropshire
    Be careful tapping them. The bolts will go in afterwards but you have no idea how strong they will be.
    Jul 2010
    rotherham
    Iv heard that about the strengh there is a hub on ebay at the moment for £33 including postage so if one from a 3.2 petrol will fit then i will buy this and if it comes by saturday i will fit it at the weekend?
    Can anybody confirm it would fit the link is below.
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
    Thanks for the responses
    Jul 2010
    rotherham
    right mad now.
    Im at work today so my bird has gone to get it re threaded. They have done one. charged her for it and then said you need a new hub cant do the other one. So iv just ended up paying £30 to get 1 done, which is no help, and now they say u need to buy a new hub :S
