Thread: Temperature Guage - 05 CDTi 150
    Oct 2010
    UK
    Default Temperature Guage - 05 CDTi 150
    Hi Guys,
    A quick question about the dashboard temperature display guage - What should I expect to see it sitting at?
    Basically mine's quite happy to not move when stationary, and when on a journey may go up to 1/3rd of the way occasionally, but mainly at 0 or just very slightly over.
    Any thoughts!?
    Cheers,
    G.
    Sep 2010
    Hartlepool
    Mine usually sits between 75 and 85. Can go up to 90 in stationary traffic.
    Expect it to be low this time of year with the colder weather.
    HTH
    Oct 2010
    London
    Mine sits about 80-85c... takes a lot to shift it to 90c and above!
    North Yorkshire
    It should sit around 85-86.
    You need a new thermostat, it's a common problem.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Quote Originally Posted by Homer View Post
    Takes around 5 miles to get warm, first difference I noticed with a diesel, but it sits there all day
    Regular Member mozzer99's Avatar
    bristol
    Quote Originally Posted by Gallen View Post
    Hi Guys,
    Any thoughts!?
    Cheers,
    G.
    Same as mine - new thermostat fixed it - now stays at 85c and plainly warms up a lot quicker. Later thermostats were modified.
    Fairly easy to fit, best to take the battery and battery box out to get easy access - not as bad as it sounds
    It should read and act in the same way as every other car you have ever driven. It should get to a temp and stay there no matter what - with in reason, about 5 degrees.
    Oct 2010
    UK
    Thanks guys and sorry for the late response on my behalf. Looks like I will have to sort out a new Thermy.
    Any ideas on ball park price, supplied & fitted?
    G.
  1. Temperature Guage
    By garetmcc79 in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2012, 15:28
  2. temperature guage ?????????
    By VEC-MAN in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2011, 09:01
  3. Temperature guage
    By Martinlw in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2010, 23:40
  4. Fitting an oil temperature guage
    By Celes in forum Diesel Engine related
    Last Post: 25th November 2009, 18:51
  5. Outside Temperature Guage
    By Del 2.2SRi in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2007, 20:10
