Page 1 of 8 123 ... LastLast
Results 1 to 10 of 76
Thread: What's your temp at?
    Aug 2010
    Derbyshire
    Default What's your temp at?
    What's your temp gauge sitting at this weather?
    BTW mine's a Signum 1.9CDTi 150
    Just done a journey of 25 miles, motorway and A roads and the temp gauge didn't manage to quite reach 80, and took around 10 miles to do so.
    Same on the return journey, but then it was idling for around 5 mins after stopping, temp then went just above 80.
    Is this normal given the the drop in outside temp, or have I a problem?
    Mick
    Huddersfield
    I'd say normal mate especially if you drive with the heater on as well as that will keep the car cooler.
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Mine gets to about 85 and sits there but it's a 2.2 DTi. It takes quite a while to heat up though. They appear to be rather cool running engines.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Been from tamworth to raf cosford meet today (cdti 150) & the temp gauge never left zero!, i've had this 04 rg from new & its never been any different.
    Aug 2010
    Derbyshire
    Quote Originally Posted by the-wizard View Post
    I would say you have a problem! Stat.
    Mine (first post) just seems slow to get upto temp, but then I've never driven in winter, bought the car this summer.
    Mick
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    You'll generally find a lot of the cdti's run cool!, some change the thermostat with good results + better mpg, but some see no change for some reason!, As i get good mpg already (currently at 50+ mpg) I see no need for change as the engine runs at normal temp but doesn't register as so, This is common for a lot of the cdti's & nothing to worry about.
    UK
    Vehicle : Vectra-C
    Trim : sxi
    Engine : 1.9 CDTI
    Quote Originally Posted by MickAP View Post
    Mick
    I've noticed quite a difference in mine between Summer and Winter. In the cooler temps, mine [120] is like yours and barely reaches 80. In the summer It'll sit at around 85-87 once up to temp.
    Are you VXR Enough
    16 Post(s)
    Vehicle : VXR8 6.0 muscle Skoda Octavia VRS
    Trim : VXR8
    Engine : 6.0 V8
    i had the same problem with the temp gauge not moving in the cold weather and thought it was just the gauge but alas i changed the thermostat and now the gauge sits on 85 and the heating and fuel consumption have improved quite dramaticaly
    thermostat was about £40 quid plus fresh antifreeze and changed in about a hour bit fiddly but otherwise ok
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Trim : Club
    Engine : Y20DTH
    Mileage : 79k
    mines a 2.0dti the past few days its been cold by me 4c the outside temp, today ive noticed that with the heaters on 3 and on hot the temp didnt even move above 80 that was stop and start tho and just driving for about 2-3 miles on each trip
    how long should it take for a dti heater to warm up? i undertsand it depends on your driving
    is there a how2 for thermostat?
    Oct 2010
    London
    mine takes about 5-10 minutes to get off the bottom and will sit at 75-80 (i think)
    too cold?
    1.9cdti 150 auto
  1. temp
    By HARRY SRI in forum Engine & Drivetrain
    Last Post: 19th January 2013, 19:44
  2. What temp should air con be ?
    By bighammerfan in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2010, 17:49
  3. DTI temp
    Last Post: 23rd September 2010, 22:53
  4. outside air temp
    By leeashford in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2010, 19:34
  5. temp
    By the fisherman in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2009, 13:52
what should the temperature at the vents ne on vectra c car air con
