Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: engine bay before and and after
  1. #11
    stockport
    Arrow
    Did you take your engine cover off?.I'm always frightened of messing things up.The last time I did my engine bay,I taped all the electrical connectors up because I was sure I was going to blow something.Took me the best part of a day to do,then the same to take it all off again!!!!.It was weeks before my fingers recovered. FELIXX.(Looks nice by the way).
  2. #12
    Oct 2010
    northampton
    1-left car running from cold
    2-left all covers on and just jetted it to get loose stuff off
    3-then coverd everywhere with a can of 1£ oven cleaner from rock bottom stores
    4-left for 5 mins
    5-jetted off thoughly
    6-repeated step 2 3 and 4 again
    7-took car for a 5 min drive
  3. #13
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    If you do want to power wash the engine whats the best way to do it, ie what precautions must be taken on a diesel engine, fancy giving my snow foam a bash on it.
  4. #14
    Vehicle : Insignia sport tourer 2.0 CDTi
    Trim : /Elite
    Mileage : 34900
    You can do the block , turbo heat shield the vacuum pump , lower throttle manifold and air con pipe work
    and still loving it
  5. #15
    Oct 2010
    northampton
    Quote Originally Posted by bobssignum View Post
    might hav a bash at it
  6. #16
    Oct 2010
    northampton
    ive done this loads of times with no probs jus leave it running while u do it and drive it straight after for a good drive u might get a sqeely belt but it does go away
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
