Thread: Replaced alternator but still probs
    Oct 2010
    hertfordshire
    Default Replaced alternator but still probs
    Good Afternoon,
    Please could someone help. I had my alternator re-conditioned due to failure last week. I have re-fitted the re-conditioned unit to my car but battery needed recharging. Recharged battery and reconnected. Started car last nite and all was well. Come to use car this morning and started fine no problems. Reset date and time (due to battery being disconnected). Drove car to local shops. Went about my business and returned and started car. Found clock and date re-set again and the spanner and car light on dash board appearred. Car keeps re-setting and don't understand. Have checked alternator and wiring fitted correctly. All help will be appreciated.
    Regular Member Dazzy2006's Avatar
    Notts
    Are you sure you tightened the battery terminals tight enough?
    Regular Member Craig1985's Avatar
    harwich essex
    when i replaced mine i had the battery light on for a few day for some reason then it has been ok since, may just take a while for the battery to get a full charge.
    Also check your battery connections?
    Oct 2010
    hertfordshire
    cheers i'l check when i next go to me car. Would the battery not fully charge when done off the car? Could be something to do with the battery maybe?. I noticed that as my alternator was failing that the clock and date display was fading in one corner but that is still the case now but i know battery has charge in it.
    Notts
    You sure the alternator had gone?
    That sounds more of a wiring fault than a dodgy alternator
    Oct 2010
    hertfordshire
    yeah had it tested at a vxl garage the day it went and all that came back as the alternator needed replacing?
  1. Replaced alternator now won't start!
    By elfrider in forum Engine & Drivetrain
    Last Post: 30th December 2012, 20:30
  2. Alternator replaced
    By 19CDTi in forum Electrical & ICE (including SatNav)
    Last Post: 4th July 2012, 10:16
  3. any one replaced the ecu?
    By twaiter in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2011, 23:44
  4. Alternator replaced but now engine management light on?
    By Dai69 in forum Engine & Drivetrain
    Last Post: 25th July 2010, 10:01
  5. Alternator replaced
    By woodaj in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2009, 14:49
