Thread: Noise from front suspension
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Default Noise from front suspension
    I get a ?clunking? noise from the front when I drive off and sometimes a weird rattle when driving on rough roads (i.e. every road ). What's the problem now? Replaced drop links, tie rods + tie rod ends and wishbones not even 6k miles ago. The springs were checked 6k ago and tested fine, so did the shock absorbers...
    Also, there is a horrible knocking noise coming from the back. Would that be bad upper control arms?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Anyone?
    Wirral
    6 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Mine's doing this. Running out of ideas as to what it might be. Worn suspension bushes? anti-roll bar? Need to get it up on ramps.
    Regular Member Jezzy's Avatar
    S.E
    There are two obvious things you haven't changed yet, so it could be those: for the front it could be the anti-roll bar bushes, and at the rear it could be the upper control arms. Hold the rear tyre at the top and see if it moves in and out a little.
    Bristol
    Vehicle : CDTI 150
    Celes, the clunking when driving off is probably a worn CV joint.
    Vehicle : Insignia sport tourer 2.0 CDTi
    Trim : /Elite
    Mileage : 34900
    Is the clunking from the front end definetly suspension related or could it be radiator mounts
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Will replace the ARB soon. I've tried to move the rear tyre and it won't budge. I'll try again tomorrow.
    Quote Originally Posted by lesj View Post
    Thought about that too...not for long though cos it's really expensive to repair
    Quote Originally Posted by bobssignum View Post
    Haven't considered this but when I flushed the coolant 10k ago the radiator mounts looked ok...
    Jan 2010
    uk
    hi guys it could be the front strut bearings i have the same issue going to replace on monday will let you know if this fixed the issue
  1. Noise from front suspension. Don't know where from
    By Lao in forum Suspension, Wheels & Brakes
    Last Post: 11th November 2009, 18:54
  2. Front suspension noise ?
    By caravaner-tony in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2008, 01:35
  3. Front suspension noise..
    By baard in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2007, 20:16
  4. front suspension noise?????
    By kev bux in forum Suspension, Wheels & Brakes
    Last Post: 20th June 2007, 18:46
  5. front suspension noise
    By Beavis in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2006, 11:18
