Results 1 to 10 of 11
Thread: Service help please
    Regular Member Rebellion8878's Avatar
    Jul 2009
    Bucks
    Default Service help please
    The car is a 1.8 VVTi has done 30k nearly, just wanted to know what sort of service it needs, what parts to get? The last service was at 20K and had the following done:
    Oil Change
    Oil Filter
    Fuel Filter
    Pollen Filter
    Panel Filter
    Had the cambelt done as well I know it was very early but had a leak on the camshaft so did that at the same time.
    Rear Brake pads as well (silly VX Dealer) Had the rest done at a local garage.
    So guessing its a minor service?
    Sep 2009
    Audley STAFFS
    yes mate minor service, oil/filter,, when the cam belt was done was it a full kit?, auxliiary belt/ rollers water pump, had my belts done at 56,000 the wter pump was on the way out. the only other thing I would check is discs and pads
    The only thing you missed was the MY, so assume it is stil lthe 2006 in your profile
    Simply repeat the previous service, less the cambelt change
    Include a brake fluid change, due in 2009 then every second year
    Also at four years / 40K miles are the spark plugs, so these are also now due
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Isnt the belt different on the VVT?
    Jul 2009
    Bucks
    It was a whole kit so should be good until 70/80k, its an 06 with 30k so are the spark plugs good for another year or as the 4 years have come around get them done? Also how many litres do I need for an oil change, guessing the panel filter and fuel filter are fine?
    Oct 2007
    south wales
    If its done 10 k since the last service, then just oil , and filter. I only do 10k a year if that, and I always change the oil, filter, pollen filter,air and plugs, but thats just me...
    Last edited by PeterVV; 6th November 2010 at 21:09. Reason: didnt read original post#1
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by Rebellion8878 View Post
    oil change is 4.25 ltrs, it would not hurt to do the plugs,, when I bought my none vvt 1.8 it was due a servive, so new GM plugs whent in only 10,000 mile later I thought I Would have a lookie see what the plugs were like as my mpg had droped quite a bit, I am glad I did, although the plugs were a perfect colour, all the plug gaps were all over the place some were massive while others were a tiny gap, the gaps had been checked when fitted, I fitted bosch super, then checked them 10,000 miles later all gaps still perfect
    Regular Member shadyone's Avatar
    Nov 2007
    Northants
    Waterpump nor driven off the timing belt on a vvt, no need to change.
    Oct 2007
    south wales
    Quote Originally Posted by shadyone View Post
    thats what I thought?
    Jul 2009
    Bucks
    There was mess all over the belt from the oil leak, just better safe than sorry when I had it done.
  1. Replies: 341
    Last Post: 20th April 2016, 06:29
  2. Service book - copy of service page (2.0 DTi)?
    By mvdg in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2011, 22:48
  3. Free MOT & Service reminder service
    By norfolk in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2010, 05:59
  4. 40k mile service and service light
    By a_j_mair in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2009, 14:41
  5. is there a way to reset service light yourself after a service?
    By EURO G in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2008, 00:14
