Results 1 to 10 of 22
Thread: Bulb replacement
    Sep 2010
    Default Bulb replacement
    Just been Reading my manual as I'm about to put some MTEC bulbs in... And it says to change the bulb on the right that the headlamp needs removing so book into a workshop!! This wasn't needed on my pre facelift 2.2 direct so can this be right for my facelift 150cdti??!!
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    I didn't for dip, took airbox off on driver's side, and washer filler neck on passenger side. With battery.fuse box cover hooked up out of way plenty of access. Read the How to's or search for bulb changes.
    Sep 2010
    yeah need some torx screws,... bout time the manufacturers packed this silly game in .. especially as it's points on license for bulbs out. Seems the days of popping your bonnet and undoing the back of the lamp set are gone
    thanks for info!
    12 Post(s)
    Quote Originally Posted by chewy71 View Post
    Since when?
    At worse you should be given a 7 day wonder, along with a form to get someone like an MOT tester to fill in to confirm the bulb(s) are now working.
    Sep 2010
    Since when?
    They could, if they wish, issue you with CU20 giving you 3 points - 'Causing or likely to cause danger by reason of use of unsuitable vehicle or using a vehicle with parts or accessories (excluding brakes, steering or tyres) in a dangerous condition'
    12 Post(s)
    I'd only accept a CU20 if they were to issue one to themselves. 3 plod cars currently being driven around the area with defective lights. 2 have a tail light out, and the other a brake light.
    Sep 2010
    I know,.. I even pulled one over and told him, he'd just pulled out of the station too so he clearly hadn't checked the car over. I know they won't give you the points and would certainly give you a warning to get it fixed.
    My father came out to pick me up form a party one evening and his light went that night, called into halfords there and then to buy a bulb and got pulled on the way home by a very condescending young officer... dad had his foglights on for what is clearly obvious reasons to which this d!ck advised him that it's an offence to drive with front foglights on when it's not foggy,.. then advised him to leave them on!!!
    12 Post(s)
    I pointed out several years ago that a tail light had gone on one of our local beat cars (an Astra-G). Plods reply was that it'll need to be booked into their vehicle workshop at Kidlington for repair. Kidlington just so happened to be nearly 30 miles away. No wonder the police are always complaining they have no money.
    Sep 2010
    I need hands the size of a 2 year old to change the drivers side.
    preston
    remove the air box entirely.... then its ok for fat fingers
  1. bulb replacement
    By temprahater in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2010, 22:29
  2. TID bulb replacement??
    By Davis87 in forum Electrical & ICE (including SatNav)
    Last Post: 29th May 2010, 18:04
  3. bulb replacement
    By clifford in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2009, 20:19
  4. HID Bulb replacement...?
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2009, 19:13
  5. bulb replacement
    By skippyroo in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2008, 00:48
vectra sat nav bulb replacement
