Thread: Headlight help!
    Nov 2009
    telford
    Default Headlight help!
    Hi all
    I had my car MOT car and sadly it failed on the drivers head light being a LHD one and not a RHD ????? How can i tell if if is correct? does anyone know the part numbers or a way of telling? also how easy it is to change?
    Nov 2009
    telford
    I forgot to mention he said the drivers side is kicking out the wrong way or something like that ( should kick to the left but is kicking to the right into on coming traffic)
    Hanging Heaton
    24 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    I'm sure there's something on the light housing to switch it back??
    Search on here for threads where people are driving in europe etc...
    Nov 2009
    telford
    i reckon that if i take the kick up off the drivers side it should pass with a flat beam then.
    Wales, UK
    Thats odd, is there something at the rear to adjust the beam angle ?
    Regular Member madman's Avatar
    nottm
    look inside the unit from the rear where you change the bulb. its a tight squeeze to get your hand in. remove the black plastic cover and inside barely visible is a white lever. flick it and that should do the trick.
    Nov 2009
    telford
    madman will this make it a flat beam or change the kick direction i will have a go at a diagram below
    should be!
    \______ \______
    but mine are like this
    \______ _______/ (drivers side is wrong )
    Hanging Heaton
    24 Post(s)
    Mileage : 140k
    Quote Originally Posted by lukesignum View Post
    should be!
    \______ \______
    Thats what it changes...
    Nov 2009
    telford
    hope your right! Saving me 50 quid. I was on abay looking but asked the questions on here first! Glad i did now!!!
    Hanging Heaton
    24 Post(s)
    Mileage : 140k
  1. headlight help pleaSE
    By jimmywhu in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2012, 17:50
  2. Headlight
    By mageamind1979 in forum Bodywork & Interior
    Last Post: 7th January 2012, 21:08
  3. DIY headlight mod day!!!!!
    By bertbuckie1 in forum Styling
    Last Post: 4th January 2011, 00:07
  4. Headlight mod .. need help
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2007, 19:18
