Thread: Voltage Showing On the BD
    Regular Member Si-SRI's Avatar
    Oct 2009
    LINCOLNSHIRE
    Default Voltage Showing On the BD
    Went through the bd computer today and the voltage is showing 13.4/5 volts..no higher...it does go down to 12ish when i load the system..heater lights etc...it does rise to around 13.1...thought though it should be higher?
    Could the alternator be on its way?
    Whats the lowest the voltage drops to...to put the dash light on?
    Regular Member gibbon7000's Avatar
    lincs
    I may well be totally wrong here but the battery is only a 12V so therefore your not gonna get much higher.
    Please correct me if i wrong, I know nothing about electrics
    Regular Member vectraturbocal's Avatar
    Aug 2010
    leeds
    it should charge at 14.33v or there around, just check the wires first before changing alternator mate.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    do you have a fault with your battery / car ?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    When my battery was on its way out it always showed slightly lower Volts even when the car was running.
    Oct 2009
    LINCOLNSHIRE
    No issues to be fair with either the alternator or battery..well none what would indicate from reading the threads on here anyway.....just having a mosey through it to be honest and saw this setting....just thought it appeared low tp be honest....
  1. oil light showing
    By twaiter in forum Engine & Drivetrain
    Last Post: 11th December 2010, 11:51
  2. Instant MPG showing 9?!?!
    By Morzy in forum Engine & Drivetrain
    Last Post: 14th September 2010, 21:03
  3. Op-Com ERROR: B3109 - Remote-Key 1 System Voltage Low Voltage
    By Jedi in forum Vectra C / Signum Troubleshooting
    Last Post: 30th June 2010, 18:17
  4. Do you have any rust showing
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2010, 19:03
  5. @rsehole showing off !
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2008, 19:55
