Results 1 to 10 of 11
Thread: fault code po606
    Jun 2009
    Chelmsford
    Default fault code po606
    Just had this code, po606 come up on Vectra, anyone have any idea what it is, my Vx tech didnt even know??
    cambs
    P0606 PCM Processor Fault
    Jun 2009
    Chelmsford
    What does that mean then, car is running fine
    Full Member ROCKATANSKY's Avatar
    Apr 2008
    suffolk
    Accorfing to TIS2000....
    REPLACE ECU
    CONTROL UNIT PROGRAMMING ERROR
    ECU MALFUNCTION
    It looks like theres are literately hundreds of things associated with that code. I'd have a look and see if there's any water ingress to the ecu
    Needs TECH2 really
    Jun 2009
    Chelmsford
    How much am i looking at to replace the ecu??
    Apr 2008
    suffolk
    No idea mate....Dont even think about it. It could be one of a million things...any other codes? TBH you'd be better spending the money and get VX to look at it
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Have you disconnected a sensor while your ignition is on or been running the engine . All the p0606 code is telling you is that it is detected an error in the system . if all your connections are ok then it should clear itself
    and still loving it
    Jun 2009
    Chelmsford
    As mentioned Spanner light came on when ignition on but went when engine started and car is running ok, mate has cleared fault and i'll see if it reappears, dont fancy having to purchase new ECU.
    Dont suppose anyone around Essex has a tech 2 to plug in and check properly??
    Engine : 2.0DTi
    Mileage : 73350
    Send a pm to plasma he is in rayleigh
    and still loving it
    Jun 2009
    Chelmsford
    Thanks will do
  1. Fault Code Help
    By rmg1 in forum Y & Z30DT Specific
    Last Post: 3rd October 2012, 21:12
  2. fault code on vec c 1.8 sri please help
    By gavs-sri in forum Engine & Drivetrain
    Last Post: 10th April 2012, 21:52
  3. Fault code
    By bellsjoe in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 22:24
  4. Help with fault code,
    By robwilson69 in forum Suspension, Wheels & Brakes
    Last Post: 13th December 2009, 21:57
  5. Fault Code
    By fattony in forum Engine & Drivetrain
    Last Post: 6th April 2009, 22:24
