Results 1 to 10 of 22
Thread: HOW much have you,,,,
    Sep 2009
    Audley STAFFS
    Default HOW much have you,,,,
    How much have you spent on your vec in the last say,, 12 months/ two years,, I dont mean on mods or service items, I mean things that have gone wrong that realy you would not have expected to, when I have the work done for my advisory/ mot, I will have spent £700 in two years just to keep it running and some say I am lucky,,
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Considerably less than that for me.
    Apart from servicing, maintenance, brakes and tyres I have bought
    new camshaft sensor
    new crankshaft sensor
    paid £85 to VX to have a go at changing an ECU.
    All the above was an attempt to cure a problem that a cambelt change during the next normal interval solved.
    Maybe bought a bulb or 2
    2 front road springs at £30 each.
    So total about £220.
    Can't think of anything else over the last 2 years.... and I have done about 60,000 miles in that time.
    Nothing on mods - as not into modding my car.
    Sep 2009
    Audley STAFFS
    Well Ste, in 60,000 miles thats what I call very good. I put this up as a friend has had enough of spending on his 150, and asked me how much I spent (none service) on my KIA Mentor in the 7 years and 74,000 miles I owned it my answer,,,, 20 quid and it was 3 years old when I got it
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Not mods or servicing? Since January this year that would be nothing then.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yeah, most of mine was trying to resolve the timing issue - I can only think it was a stretched timing belt, spent money on stuff and it didn't cure the problem. Routine change of belt sorted it though. So otherwise only 2 road springs and a couple of bulbs (apart from servicing, maintenance and rubber) in the last 2 years - so can't complain.
    TBH, if anything expensive needs doing, I may n ot bother. The car is prob only worth £500 now due to the 154,000 miles on the clock. 'webuyanycar' valued it at £510 a couple of months ago.
    Nov 2009
    Norfolk
    Um... £650 for new exhaust, old one blowing and falling appart so worked out cheaper to get a custom powerflow!
    Had a spring snap, so have all been replaced with Eibach's £160
    Rear contol arms are getting done soon which is £180 fitted.
    So £810 so far, but will be £990 !! but all this is nothing compared to visiting the petrol station with a 3.2
    Car has also just had a Major service and Cam belt so plenty more spent!
    May 2006
    Mansfield
    Well at 66k miles I am now at the stage of having/had to spend some cash
    New Clutch (coverplate on original disintegrated) £425
    New Springs + Rear Fixed brake Pipes £560
    New exhaust (from MIJ) £365
    New Fan Regulator £160 last January, snow had partially melted and refroze in the drain tube so when the new snow melted it came flooding in through the pollen filter
    SJ
    Aug 2010
    Leeds
    Nothing £0.00 It's under warranty 58 plate.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    £0, Nothing as well. Ok only had it since the middle of June but so far so good(touch wood). Do have an EML issue but it does not affect the cars running and the only the problem was the dashboard issue that cured itself and that's not come back.
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by fastcarmanaic View Post
    springs and exhaust don't count , they go an any car, so not to bad then
